Will 22 AWG 9ft Cable Handle 2.1A for Tablet Charging at 5.1V With LED Load?
297 6
  • 22 awg voltage drop over 9 ft charging cable
    #1 21671872
    alumaline
  • 22 AWG cable voltage drop and heating calculation
    #2 21671873
    Steve Lawson
  • #3 21671874
    alumaline
  • #4 21671875
    Steve Lawson
  • Return-line resistance may dominate voltage drop
    #5 21671876
    Mark Nelson
  • #6 21671877
    alumaline
  • #7 21671878
    alumaline
A 22 AWG, 9-foot cable with 46 strands of 0.1 mm tinned copper is evaluated for tablet charging at 5.1 V and 2.1 A current, including powering an LED load. The fusing current for 22 AWG wire is approximately 41 A, indicating no risk of melting under 2.1 A load. The calculated voltage drop over 9 feet is about 0.15 V at 1 A and 0.3 V at 2.1 A, which keeps the voltage within the specified range (4.55 V to 5.25 V). However, the return path (drain wire) resistance, likely similar to or higher than the 22 AWG conductor, must be considered as it contributes to total voltage drop. The cable design is close to the maximum allowable voltage drop with minimal margin for manufacturing variation. To meet Apple’s USB 2.0 DC resistance requirements (round trip VBus with shield shorted to GND below 200 mΩ), a larger gauge conductor or multiple smaller conductors may be necessary, balancing voltage drop, cable flexibility, and stiffness. EMI shielding with AL/Mylar and drain wires are included in the cable construction.
