How to Reduce RF/EMI Noise in 3.7V MP3 Recorder With SD Card and Small Microphone?
282 6
  • #1 21674367
    Andrew Feder
  • 22 ohms chassis-to-earth resistor and balanced mic input
    #2 21674368
    Sambath Kumar
  • #3 21674369
    Andrew Feder
  • #4 21674370
    Sambath Kumar
  • #5 21674371
    Andrew Feder
  • #6 21674372
    Sambath Kumar
  • #7 21674373
    Sambath Kumar
The discussion addresses EMI/RFI noise interference in a 3.7V MP3 recorder with an SD card and a small microphone, causing high-pitched audio noise. Solutions include connecting a 22-ohm 2-watt resistor between the AC power earth terminal and the equipment chassis, which is then connected to the DC negative supply to create an earth loop that reduces noise ingress. Using balanced input connections for the microphone is recommended, but since the microphone is unbalanced, adding a balancing circuit is suggested. Additional noise suppression involves placing a 0.1µF capacitor in parallel with a 10µF 25V electrolytic capacitor across the DC supply, observing correct polarity. A balancing circuit diagram was offered to assist in converting the unbalanced microphone output to balanced input, further mitigating noise. The specific device referenced is a Waytronic voice module recorder.
