How Does the 5V Rectifier Circuit Protection Circuit Work With Red and Green LEDs?
312 7
  • Request for explanation of red-green rectifier protection circuit
    #1 21675991
    Sourav Kumar
  • LED resistor values are too high for visible current
    #2 21675992
    Dean Franks
  • Need lower resistor values for brighter LED output
    #3 21675993
    Sourav Kumar
  • #4 21675994
    Sambath Kumar
  • #5 21675995
    Sourav Kumar
  • #6 21675996
    Sambath Kumar
  • #7 21675997
    Sourav Kumar
  • #8 21675998
    Sambath Kumar
The discussion focuses on understanding the operation of a 5V rectifier circuit protection system featuring red and green LEDs as status indicators. Under normal conditions, the green LED glows, indicating proper output, while the red LED remains off. When the output is shorted, the red LED illuminates, and the green LED turns off. The circuit includes an Over Voltage Protection (OVP) shunt and LED indicators, with the LEDs lighting based on potential differences across the circuit nodes. The original resistor values (470kΩ and 270kΩ) were too high, resulting in insufficient current to properly illuminate the LEDs. It was recommended to reduce resistor values to around 470Ω to achieve adequate LED brightness. The user sought further explanation of the transistor operation within the OVP circuit, with additional resources provided to clarify the transistor switching mechanism controlling the LED indicators based on output conditions.
