Connecting external self-made device to micro-usb port of the smartphone
315 9
Can I send analog voltage changes directly into a smartphone’s micro-USB port, and what sampling rate/data conversion would be possible?
No—you generally cannot feed analog voltage changes straight into a phone’s micro-USB data pins; you need a USB-capable interface and, for voltage measurements, an ADC, plus a phone app to receive and decode the data [#21678247][#21678250][#21678253] Most smartphones are USB 2.0 compliant, so the raw link can reach 480 Mbit/s, with practical throughput usually under about 400 Mbit/s because of overhead [#21678253] The real limit is usually the ADC, not the USB port: pick the ADC by its resolution (bits per sample) and conversion rate (samples per second), then multiply them to estimate the data rate [#21678253][#21678254] For example, an 18-bit 1 MSps ADC produces 18 Mbit/s, which is well within USB 2.0 capability [#21678253] If you want steady streaming, USB 2.0 isochronous mode is intended for that and offers about 8, 16, or 24 MBytes/sec [#21678255]
  • #1 21678246
    Ruslan Tazhkenov
  • Suggesting USB-to-serial or BLE instead
    #2 21678247
    David Ashton
  • Bluetooth modules or audio jack for phone interface
    #3 21678248
    Duane Benson
  • Simblee module for smartphone UI and signal monitoring
    #4 21678249
    Max Maxfield
  • Bluetooth or WiFi easier than USB data collection
    #5 21678250
    Elizabeth Simon
  • Micro-USB requires a digital USB converter
    #6 21678251
    Ruslan Tazhkenov
  • #7 21678252
    Ruslan Tazhkenov
  • USB 2.0 bandwidth and ADC limits for smartphone input
    #8 21678253
    Elizabeth Simon
  • PIC microcontroller for ADC and USB connectivity
    #9 21678254
    Chip Fryer
  • #10 21678255
    PeterTraneus Anderson
Directly sending analog voltage signals to a smartphone's micro-USB data pins is not feasible without proper conversion. A USB-to-serial converter or an analog-to-digital converter (ADC) is required to digitize voltage signals before transmission. Smartphones typically comply with USB 2.0 standards, offering theoretical maximum data rates up to 480 Mbit/sec, with practical throughput around 400 Mbit/sec. The actual sampling frequency achievable depends primarily on the ADC's resolution and conversion rate rather than the USB interface itself. For example, an 18-bit ADC sampling at 1 MSps generates 18 Mbit/sec, well within USB 2.0 capabilities. Isochronous USB 2.0 mode supports steady streaming at 8 to 24 MBytes/sec, suitable for high-speed ADC data transfer. Alternative wireless solutions such as Bluetooth Low Energy (BLE) modules (e.g., Simblee, Adafruit Bluefruit) or WiFi modules (e.g., ESP8266) can simplify data communication without cables but may have different bandwidth and latency characteristics. Audio jack interfaces offer about 43 kHz sampling frequency but require additional research for implementation. Custom smartphone applications are necessary to receive and decode incoming data from USB or wireless modules.
