Safely Drawing 5V Power from USB Port: Current Limits, Wiring, and Considerations
768 17
Can I safely draw 5 V power from a USB port, and what current and wiring limits should I follow?
Yes—if you only use the +5 V and GND pins and keep the load within USB limits, you can power a small device from a USB port, but the usable current depends on the host and whether the device enumerates [#21659351][#21659349] A USB 2.0 port is commonly limited to 500 mA, but a device is only guaranteed 100 mA in normal operation unless it requests and is granted more during enumeration [#21659349][#21659352] Desktop machines often have a polyfuse on the USB power line and will usually tolerate simple 5 V loads, while laptops and other mobile hosts may enforce stricter power management and can shut the port down [#21659351] If your circuit also presents a USB interface, current can be requested during enumeration; otherwise, a passive power-only connection may work on some hosts but is not guaranteed across all systems [#21659349][#21659351]
  • #1 21659340
    Bob Casiano
  • #2 21659341
    Chris Roth
  • #3 21659342
    Cody Miller
  • #4 21659343
    Dan Oh
  • #5 21659344
    Bob Casiano
  • #6 21659345
    David Figueroa
  • #7 21659346
    Bob Casiano
  • #8 21659347
    Bob Casiano
  • #9 21659348
    David Figueroa
  • USB enumeration can request higher current draw
    #10 21659349
    Jeff Evemy
  • #11 21659350
    Alec
  • USB power limits differ between desktops and laptops
    #12 21659351
    Olin Lathrop
  • #13 21659352
    Olin Lathrop
  • USB 2.0 current limit and FTDI recommendation
    #14 21659353
    Dorin Dragan
  • #15 21659354
    Bob Casiano
  • #16 21659355
    Alec
  • #17 21659356
    Alec
  • #18 21659357
    Bob Casiano
Drawing 5 V power from a USB port requires consideration of the USB power specifications and port behavior. Standard USB 2.0 ports provide up to 500 mA current, but devices are initially guaranteed only 100 mA unless they request and are granted more power during enumeration. Drawing more than the default current without proper negotiation may trigger power surge warnings or cause the port to shut down, especially on laptops and mobile devices with stricter power management. The USB pinout for power-only connections uses pin 1 for +5 V and pin 4 for ground, with pins 2 and 3 reserved for data lines. Using off-the-shelf USB cables with mini-USB connectors is common for such projects. For devices involving data transfer, USB interface chips like the FTDI FT232 series are recommended due to their ease of use and reliable performance. Developers can refer to official USB specifications and tools for compliance and enumeration protocols. Passive methods to draw more power without enumeration are generally unreliable and not recommended.
TL;DR: You can draw 5V from USB; USB 2.0 allows up to 500 mA, but “A USB device is guaranteed 100mA” unless it enumerates for more. [Elektroda, Olin Lathrop, post #21659351]
Why it matters: This FAQ helps makers and engineers wire USB power safely, avoid port shutdowns, and size loads correctly.
Can I power my project from a USB port safely?
Yes, if you respect limits and wiring. USB 2.0 guarantees 100 mA without negotiation. You can request more during enumeration. Desktops often protect ports with a polyfuse tied to the 5 V rail. Laptops may enforce stricter policies and shut ports. [Elektroda, Olin Lathrop, post #21659351]
What is the maximum current without enumeration?
Without enumeration, design for 100 mA. That is the guaranteed current in normal operation. To exceed it, the device must ask and be granted more. “A USB device is guaranteed 100mA in normal operation.” [Elektroda, Alec, post #21659355]
How do I get more than 100 mA from USB?
Implement USB enumeration and request additional current. The host operating system may approve or deny the request. If it denies, it can shut the device down. Plan for policy differences across hosts, especially laptops. [Elektroda, Olin Lathrop, post #21659351]
What happens if I try to pull about 250 mA without asking?
You may trigger a “USB power surge” warning. Some hosts default to lower allowed current, around 90 mA. The device might still run but this is messy and unreliable. Avoid this approach in products. [Elektroda, Jeff Evemy, post #21659349]
What’s the correct USB 2.0 pinout for power-only wiring?
Use: Pin 1 = +5 V (VBUS), Pin 2 = D−, Pin 3 = D+, Pin 4 = GND, and connect the shield appropriately to chassis. For power-only, route Pin 1 and Pin 4. Verify cable and connector ratings. [Elektroda, David Figueroa, post #21659348]
Do laptops and desktops behave differently for USB power?
Yes. Desktops often use a polyfuse from the 5 V rail and are tolerant within spec. Laptops enforce tighter power management. They can limit, require enumeration, or shut the port if current is excessive. [Elektroda, Olin Lathrop, post #21659351]
What is USB enumeration in this context?
Enumeration is the process where a device identifies itself and requests resources. For power, a device can request more than 100 mA. The OS decides whether to grant that budget. Without it, only 100 mA is guaranteed. [Elektroda, Olin Lathrop, post #21659351]
Can I trick the OS to get more power without data lines?
No reliable method exists. Drawing extra current without enumeration risks shutdowns or warnings. Hosts, especially laptops, may cut the port. Design a proper USB interface if you need more current. [Elektroda, Olin Lathrop, post #21659351]
Should I use an FTDI bridge if I also need data?
Yes. FTDI parts like the FT232 simplify USB communication and current budgeting during enumeration. They are well documented and proven in commercial products. “Easy to use and precise in performance.” [Elektroda, Jeff Evemy, post #21659349]
Any tools to check USB power compliance?
Yes. The USB-IF host and device tools help validate behavior and compliance. Use them to observe negotiation and current draw during development. This reduces field failures and returns. [Elektroda, Dorin Dragan, post #21659353]
What is a polyfuse and why does it matter on USB?
A polyfuse is a resettable fuse. Many desktop motherboards place it between the internal 5 V rail and the USB VBUS line. It limits fault current and self-resets, protecting the host during overloads. [Elektroda, Olin Lathrop, post #21659351]
How do I wire a mini‑USB connector for 5 V power only?
  1. Connect Pin 1 to your 5 V input through appropriate filtering.
  2. Connect Pin 4 to system ground; tie shield to chassis as needed.
  3. Leave D+ and D− unconnected if no data is required; respect current limits. [Elektroda, David Figueroa, post #21659348]
What are USB power units in the spec?
Power is discussed in units of 100 mA. Hosts may provide more or fewer units depending on policy and negotiation. Design conservatively around these units for portability across hosts. [Elektroda, Dorin Dragan, post #21659353]
Will a simple power-only dongle always work?
It can work on many desktops if you stay within 100 mA. Exceeding that without enumeration risks port disable on laptops. Build for enumeration when loads vary or exceed 100 mA. [Elektroda, Olin Lathrop, post #21659351]
Edge case: what if the host is in a low-power or standby mode?
Some modes require devices to draw well under 100 mA. Hosts may cut VBUS or enforce strict limits. Budget your standby current accordingly to avoid disconnects. [Elektroda, Olin Lathrop, post #21659351]
