Is 40V Induced Current from Heat Mat Causing Shocks in Stainless Steel Shower Drain?
234 9
Can a heated shower-floor mat be causing about 40 V on a stainless steel drain and shocking the bather, and how should it be checked or fixed?
Yes, the thread points to a leakage/stray-voltage problem from the heating system rather than harmless induction, with the shower drain acting as the only path to ground. The electrician should leave the system off until it is resolved and use an AC voltmeter with one lead on a known good ground to probe the drain grate, taps, shower head, and other metal parts to find what is actually energized [#21680323] The homeowner’s tests showed the ~40 V appears only when the mat is heating, and the shock appears only when the drain is connected to ground or when a person in wet shower water touches grounded plumbing; when the drain is isolated, there is no shock [#21680325] If bonding the drain to ground results in only a few mA, a permanent ground bond to the drain may be a practical fix, or a non-metallic drain could be used instead [#21680326] Because a fault could worsen and the mat is on a dedicated GFCI, the electrician and manufacturer should diagnose it rather than demoing the floor immediately [#21680318][#21680326]
  • Grounding fault or bonding issue suspected
    #1 21680317
    Neil Jackson
  • Suspected leakage, not induced current from heat mat
    #2 21680318
    David Ashton
  • #3 21680319
    Neil Jackson
  • Electrician should lead until hazard is resolved
    #4 21680320
    Rick Curl
  • #5 21680321
    Neil Jackson
  • Shut off power and have electrician fix fault
    #6 21680322
    David Ashton
  • Recommend tracing the shock source with a grounded AC voltmeter
    #7 21680323
    David Ashton
  • #8 21680324
    Neil Jackson
  • Drain only becomes live when grounded
    #9 21680325
    Neil Jackson
  • Measure drain-to-ground current before adding permanent bond
    #10 21680326
    David Ashton
A tile contractor installed a walk-in shower with a stainless steel linear drain and a heat mat under a slate-look tile floor outside the shower area. The heat mat, powered by a licensed electrician, reportedly induces approximately 40 volts on the stainless steel drain when active, causing electric shocks to the user. The drain system is isolated with a PVC liner and liquid rubber shower pan, and the heating system is on a dedicated GFCI circuit with a sensitive thermostat. The manufacturer and electrician confirmed the voltage presence only during heating. Discussions suggest the voltage may be due to leakage or induced current rather than proper earthing, and grounding the drain reduces or eliminates the shock. Recommendations include the electrician performing AC voltage and current leakage tests, verifying grounding of metal components, and possibly installing a UL ground clamp on the drain. Alternatives such as replacing the metal drain with a non-metallic one were also considered. The consensus emphasizes the electrician’s responsibility to diagnose and resolve the issue safely, with the shower system turned off until fixed to prevent electrocution risk.
