regarding getting mild electric shock in my new (one day old) “microsoft surface pro”
330 6
  • #1 21680355
    sidhanth c
  • Suggesting house wiring tests and location swap check
    #2 21680356
    Conrad Mannering
  • Leakage shock appears only while charging
    #3 21680357
    sidhanth c
  • Suggest measuring leakage current with a multimeter
    #4 21680358
    Rick Curl
  • Suggesting a socket tester and checking for counterfeit charger
    #5 21680359
    Conrad Mannering
  • #6 21680360
    PeterTraneus Anderson
  • Reverse plug polarity or use 1:1 isolation transformer
    #7 21680361
    Sambath Kumar
A consumer reported experiencing mild electric shocks from a brand new Microsoft Surface Pro device while charging, particularly when the battery reaches 70-85%. The shocks occur upon contact with the metal body, even when wearing shoes, and are absent when running on battery power alone. The user confirmed proper voltage output, grounding of the circuit board, and replaced the power socket without resolving the issue. The problem persisted despite device replacement by Microsoft. Responses suggest the issue may stem from supply wiring faults, polarity reversal, or leakage currents in the power supply or charger. Testing with a multimeter in AC microamps range between the device chassis and earth ground is recommended to detect leakage. Use of a mains wiring socket tester or line tester to verify correct socket wiring and polarity is advised. The possibility of electromagnetic hypersensitivity was mentioned but considered less likely. If the device uses a two-pin power cord, polarity reversal may reduce leakage shocks. A 1:1 isolation transformer rated above device power requirements can eliminate leakage by isolating the device from mains earth faults. Concerns about counterfeit or low-quality power supplies accompanying the Surface Pro were raised. Testing the device at different locations can help isolate whether the fault lies in the device or the local electrical installation.
