Is there any kind of anti-electrical creme? Like an anti-conductive skin creme?
297 11
Is there a safe anti-conductive skin cream that can protect against electric shocks or electromagnetic exposure?
No skin cream is a reliable or safe way to protect yourself from electric shock or radio/microwave exposure [#21680552][#21680553] Vaseline (petroleum jelly) is non-conductive, and liquid latex or PlastiDip might offer some protection from very low voltages, but they are thin, can be pierced easily, and are not intended or rated for use on skin or for mains voltages [#21680553][#21680555][#21680552] The replies explicitly warn not to trust your life to these materials and recommend proper rubber gloves instead [#21680552][#21680553] For microwave or radio fields, an insulating cream on the skin would not help because the waves would pass straight through it [#21680557] Aluminum foil would reflect radio waves somewhat, but it is not a practical full-time solution [#21680557]
  • #1 21680551
    Erik Haugen
  • Plasti Dip suggested, but unsafe for skin protection
    #2 21680552
    Rick Curl
  • #3 21680553
    David Ashton
  • #4 21680554
    Erik Haugen
  • Plasti-Dip or liquid latex for low voltages
    #5 21680555
    David Ashton
  • Latex and vaseline suggested as discreet protection
    #6 21680556
    Erik Haugen
  • Skin insulation won’t block radio or microwave fields
    #7 21680557
    David Ashton
  • #8 21680558
    ena william
  • #9 21680559
    Max Maxfield
  • #10 21680560
    Max Maxfield
  • Aluminum foil and medieval armor as shielding ideas
    #11 21680561
    Max Maxfield
  • #12 21680562
    Rick Curl
The discussion addresses the inquiry about the existence of skin creams or topical products that can block or insulate against electrical current transmission. It is clarified that no known skin cream is designed or safe for electrical insulation, especially against hazardous voltages. Products like PlastiDip, a tool handle dip and brush-on electrical tape, are mentioned but are not intended for skin application and pose safety risks. Vaseline (petroleum jelly) and liquid latex are suggested as potential low-voltage barriers; however, their protective capability is limited, easily compromised by sharp objects, and unsuitable for mains voltage or high-voltage exposure. The original poster describes a unique concern involving microwave-based AC current attacks, noting that latex clothing provides some protection, but discrete solutions for everyday environments are sought. It is emphasized that insulating materials on skin do not block microwave or radio frequency radiation, which penetrate such barriers; aluminum foil can reflect radio waves but is impractical for daily wear. Additional cautions include the risk of heatstroke from full-body liquid latex application due to pore blockage. Overall, no topical cream or skin-safe product reliably insulates against electrical or microwave radiation, and conventional protective gear like rubber gloves or specialized shielding materials are recommended for electrical safety.
TL;DR: There’s no safe “anti‑electric” skin cream; users report shocks even around 48–60 V, and “DO NOT use any of these products for mains voltages.” [Elektroda, Anonymous, post #21680555]
Why it matters: People search for quick fixes to avoid shocks; this FAQ explains what works, what doesn’t, and safer alternatives for hobbyists and electronics learners.
Is there any anti‑conductive skin cream that actually blocks electricity?
No. Forum contributors say there’s no skin‑safe cream designed or rated to stop electric shock. Do not rely on improvised coatings. Use proper PPE like rated rubber gloves and insulated tools instead of topical products. Electrical safety requires gear tested to standards, not cosmetics. [Elektroda, Anonymous, post #21680552]
Will petroleum jelly (Vaseline) insulate me from shocks?
Petroleum jelly is generally non‑conductive, but it creates only a thin film. A sharp edge or rough surface can pierce it and let current through. It is unsafe for any mains exposure. “Stick to rubber gloves,” not jelly. [Elektroda, Anonymous, post #21680553]
Is liquid latex a good barrier against electricity?
No. Latex on skin is not a rated electrical insulator for shock protection. It can also block pores and trap heat, creating separate health risks when applied widely. Don’t use cosmetic latex where certified insulating gloves or barriers are required. [Elektroda, Anonymous, post #21680559]
Can I brush on Plasti Dip or liquid electrical tape as protection?
A poster mentioned Plasti Dip and brush‑on tape for tools, not skin. It’s messy, expensive, and dangerous when misused. “I would definitely not trust my life on it.” These products aren’t certified for dermal application or personal protection. [Elektroda, Anonymous, post #21680552]
Does aluminum foil block microwave or RF attacks?
Aluminum foil reflects radio waves to some degree, so it can reduce incident RF. However, it’s impractical as clothing and not a dependable personal‑safety solution. It does not replace proper shielding practices or workplace measures. [Elektroda, Anonymous, post #21680557]
What voltages did users report feeling, and what does that mean for safety?
One contributor reported experiencing mild shocks at around 48–60 V. That number is a warning, not a target. Low voltage can still hurt or startle, causing secondary injury. Don’t assume anything “feels mild” is safe without proper isolation and PPE. [Elektroda, Anonymous, post #21680555]
Are there health risks to full‑body latex or body paint?
Yes. A poster warned that full‑body coatings can cover pores and raise heatstroke risk. Electrical protection aside, extended wear increases thermal stress. Use breathable PPE designed for humans, not theatrical coatings, when working near electrical hazards. [Elektroda, Anonymous, post #21680559]
What should I wear for basic low‑voltage electronics work?
Wear intact, rated rubber or nitrile gloves as appropriate, and use insulated tools. Keep jewelry off and work on a non‑conductive mat. Do not substitute petroleum jelly, latex makeup, or brush‑on coatings for protective equipment. [Elektroda, Anonymous, post #21680553]
Will creams or latex protect me from long‑range AC or microwave exposure?
No. A responder noted that insulating skin coatings won’t stop microwaves or other RF fields; they pass through. Topicals are ineffective against distant emitters. RF management requires shielding, distance, and professional assessment. [Elektroda, Anonymous, post #21680557]
How can I reduce accidental contact risk during bench testing?
  1. Wear rated rubber gloves and inspect them before use.
  2. Use insulated tools and keep one hand away from the circuit.
  3. Remove sharp probes when not measuring to avoid puncturing thin barriers. These habits beat any topical coating. [Elektroda, Anonymous, post #21680553]
Why is relying on improvised insulation dangerous?
Improvised layers are thin, untested, and easily punctured by a rough or sharp point. They provide a false sense of security around live parts, including 120/240 V. Properly rated gloves and barriers exist for a reason. [Elektroda, Anonymous, post #21680553]
What if I believe I’m being targeted with EM or microwave attacks?
A forum reply stressed that skin coatings won’t block microwaves or AC fields. If concerned, seek workplace evaluations and medical advice, not cosmetic barriers. Document incidents and escalate through appropriate safety channels instead. [Elektroda, Anonymous, post #21680557]
