Designing an LED alarm clock with light sensor, dual alarms, auto DST—where to start?
354 9
How should I get started designing an LED alarm clock with a light sensor, dual alarms, and automatic DST adjustment while keeping the part count low?
Start with an ESP32 rather than trying to build it from discrete logic: it can be programmed like an Arduino, has WiFi, Bluetooth, plenty of I/O and processing power, and can sync the time over WiFi so daylight-saving changes are handled automatically [#21680632][#21680633] Use the ESP32’s PWM output to dim the LEDs based on a photodiode or light sensor [#21680633] If you want a classic 4-digit, 7-segment display, there should be enough pins to drive it directly [#21680633] You can implement the dual alarms in firmware and add buttons so the alarms can be adjusted [#21680633] If you want an easier first prototype, an Arduino variant with an LED display, light sensor, and clock module from SparkFun or Adafruit was also suggested [#21680630]
  • Component-minimal approach for a feature-rich alarm clock
    #1 21680629
    John Nash
  • #2 21680630
    Elizabeth Simon
  • PSoC5 board suggested for clock design
    #3 21680631
    Aubrey Kagan
  • ESP32 with WiFi for internet time sync
    #4 21680632
    David Ashton
  • ESP32 recommended for WiFi time sync and LED dimming
    #5 21680633
    Mike P OKeeffe
  • #6 21680634
    Max Maxfield
  • Suggesting LPC2388 or PIC24F with RTC
    #7 21680635
    Aubrey Kagan
  • #8 21680636
    John Nash
  • #9 21680637
    Cologne LED
  • #10 21680638
    Dave Lebron
The discussion focuses on designing an LED alarm clock featuring a light sensor for automatic LED dimming, dual alarms, and automatic daylight saving time (DST) adjustment. Given the lack of electronics design background but programming experience, the recommended approach is to use microcontroller development platforms to simplify hardware integration and reduce component count. Arduino variants are suggested for ease of use, with modules from suppliers like SparkFun or Adafruit for LEDs, light sensors, and clock functions. Alternatives include the ESP32 microcontroller, which offers WiFi connectivity for internet time synchronization (enabling automatic DST), Bluetooth, and sufficient I/O pins to control 7-segment LED displays and handle input buttons for alarm settings. The ESP32 supports PWM output for LED dimming and can be programmed similarly to Arduino. Other microcontrollers with built-in real-time clocks (RTCs) such as the NXP LPC2388 and Microchip PIC24F series are mentioned, though development boards for some may be obsolete or less accessible. The PSoC5 development board (CY8CKIT-059) is noted for its configurable I/O including clock/calendar and LED drivers, but with some unspecified drawbacks. Overall, using a microcontroller with integrated RTC or WiFi time synchronization is the most practical solution to minimize components and cost while meeting the project requirements.
