Can I Replace 10uF Disc Ceramic Capacitor C4 With Electrolytic in PICMeter Part2?
192 6
  • Electrolytic substitute for 10 µF ceramic C4 questioned
    #1 21680728
    Ken Bush
  • #2 21680729
    PeterTraneus Anderson
  • #3 21680730
    Ken Bush
  • #4 21680731
  • VCAP needs 10 µF low-ESR capacitor
    #5 21680732
    Ian Stedman
  • #6 21680733
    Ken Bush
  • Clarifying AVDD and AVSS pin connections
    #7 21680734
    Ken Bush
The discussion addresses the feasibility of replacing a 10uF disc ceramic capacitor (C4) in the PICMeter Part2 circuit with an electrolytic capacitor due to availability and cost issues. It is clarified that if C4 is part of a power supply filter, an electrolytic capacitor might suffice; however, since C4 is in a signal path or involved in precision timing, a ceramic capacitor's capacitance instability with temperature and voltage makes electrolytic capacitors unsuitable. A 10uF film capacitor is recommended for better stability. Further, C4 serves as a low ESR capacitor for the built-in 3.3V regulator, and a 10uF Tantalum capacitor is advised for reliable operation, referencing the PIC24FV16MK202 datasheet. The user decides to order 10uF Tantalum capacitors to improve circuit reliability. Additional notes mention schematic pin connections for AVDD and AVSS and initial successful display operation, though input voltage response issues remain.
