Compatibility of Infineon FS450R12KE3 vs FS450R17KE3 With ABB AGDR-71C Driver
405 7
  • #1 21681147
    Wayne Nguyen
  • Need to measure collector-emitter spike voltage
    #2 21681148
    Rick Curl
  • #3 21681149
    Richard Gabric
  • Asking whether FS450R12KE3 can replace FS450R17KE3 with AGDR71C
    #4 21681150
    Wayne Nguyen
  • #5 21681151
    Cologne LED
  • Need peak-voltage measurements before using 1200 V IGBTs
    #6 21681152
    Rick Curl
  • #7 21681153
    Max Maxfield
  • Infineon simulation tools for loss and thermal estimates
    #8 21681154
    neha dubey
The discussion addresses the compatibility of replacing the Infineon IGBT module FS450R17KE3 (rated at 1700 V) with the FS450R12KE3 (rated at 1200 V) in conjunction with the ABB AGDR-71C driver. The primary concern is the reduced voltage rating of the FS450R12KE3, which may compromise the safety margin under high-voltage spikes in motor drive applications. It is recommended to measure the peak voltage across the existing FS450R17KE3 using an oscilloscope with a high-voltage (x100) and isolated probe or a multimeter with peak-hold capability rated above 1 kV to assess if the lower voltage module can safely replace the higher voltage one. The ABB drive system likely uses the higher voltage module for a reason, so careful evaluation of worst-case voltage spikes is essential before substitution. Additional support can be sought from Infineon’s local technical representatives. Simulation tools such as Infineon’s IPOSIM and motor drive simulators are mentioned for evaluating power loss and junction temperature under static load conditions to aid in device assessment.
