How Does the Clock Move Instructions Through Each Stage in MIPS Single-Cycle Datapath?
303 10
How does the clock move an instruction from one stage to the next in a MIPS pipelined datapath?
The clock does not physically move the instruction; it latches each stage’s output into pipeline registers at the clock edge, and that latched result becomes the next stage’s input on the following cycle [#21681866] Think of the pipeline as blocks of combinational logic separated by registers, like a shift register, where the instruction’s data and control bits flow stage by stage [#21681861][#21681869] In an N-stage pipeline, one instruction takes N clock cycles to pass through all N stages, but all stages can work in parallel on different instructions [#21681867] For example, with three stages, cycle 1 does A step 1 in stage 1, cycle 2 has A in stage 2 and B in stage 1, and cycle 3 has A in stage 3, B in stage 2, and C in stage 1 [#21681867] Each stage is designed to take one clock cycle, and the slowest stage sets the clock period [#21681868]
  • Clock drives pipeline register updates between stages
    #1 21681859
    Ryan Mco
  • #2 21681860
    Ryan Mco
  • Instruction bits flow through pipeline stage registers
    #3 21681861
    John Beetem
  • #4 21681862
    Ryan Mco
  • #5 21681863
    Ryan Mco
  • Clarifying why pipeline stages need separate clock cycles
    #6 21681864
    Ryan Mco
  • Clarifying why pipeline stages do not take multiple clocks
    #7 21681865
    Ryan Mco
  • Pipeline registers clock stage outputs between cycles
    #8 21681866
    John Beetem
  • Pipeline timing explained with three instructions
    #9 21681867
    John Beetem
  • Pipeline stages each take one clock cycle
    #10 21681868
    John Beetem
  • Pipeline stages are delayed by clock cycles, not lengthened
    #11 21681869
    PeterTraneus Anderson
The discussion clarifies how the clock signal controls instruction progression through each stage in a MIPS single-cycle datapath pipeline. Each pipeline stage consists of combinational logic separated by registers (built from D flip-flops) that store outputs at the clock edge, effectively passing data and control signals to the next stage at each clock cycle. This mechanism ensures that at the end of one clock cycle, the output of one stage becomes the input of the next, enabling instructions to move forward step-by-step synchronously with the clock. Although each stage typically takes one clock cycle to complete its operation, the overall instruction execution spans multiple cycles as it passes through all pipeline stages sequentially. The pipeline allows multiple instructions to be processed simultaneously at different stages, with each clock cycle introducing a new instruction into the first stage and advancing others forward. The clock frequency is determined by the slowest pipeline stage to ensure proper operation. Understanding shift registers and D flip-flops helps grasp how data is latched and shifted through pipeline registers, illustrating the clock's role in advancing instructions through the datapath.
