Using a Cheap Desktop CNC With 2.5W Laser for PCB Drilling and Milling Capabilities
396 26
Can a cheap desktop CNC with a 2.5W laser reliably drill PCB holes and mill simple PCB and plastic parts?
Yes — it can drill PCB holes reliably and mill simple isolation tracks and light plastic cuts, but it needs careful setup and is best suited to hobby/prototype work rather than fine, dense PCB artwork [#21681962][#21681969] For PCB milling, the best results came from shallow V-bit cuts with height mapping: a 0.1mm 60° V-cutter worked best in later tests, with cuts around 0.06–0.093mm, feed rates from about 25 to 100mm/min, and probing a height map on a 4mm grid to compensate for board unevenness [#21681972][#21681973][#21681978] Drilling and milling were repeatable enough that the board could be drilled, cut out, and even routed between IC pins, though very fine tracks were close to the limit and the user kept chemical etching as a fallback for tougher boards [#21681969][#21681973] The practical workflow was to generate G-code from TINA or FlatCAM, unplug the hand controller before connecting Candle over USB, and use Z-probe/height mapping for each tool change [#21681961][#21681978] The machine also benefited from simple mods like a cooling fan for the controller heatsinks, step-clamps or double-sided tape for holding PCB stock, and dust control/P3 masking because FR4 dust is hazardous [#21681972][#21681974][#21681980][#21681982]
  • Cheap desktop CNC for PCB drilling and milling
    #1 21681956
    Chip Fryer
  • Request for kit link and trial photos
    #2 21681957
    Alan Winstanley
  • #3 21681958
    Chip Fryer
  • Assembly issues and mounting fixes for the CNC kit
    #4 21681959
    Chip Fryer
  • #5 21681960
    Chip Fryer
  • Handheld controller blocks USB communication
    #6 21681961
    Chip Fryer
  • First PCB milling test succeeded with TINA G-code
    #7 21681962
    Chip Fryer
  • #8 21681963
    David Ashton
  • Track depth affects V-cut width and trace clearance
    #9 21681964
    Chip Fryer
  • Gerber to G-code software options for CNC PCB work
    #10 21681965
    Chip Fryer
  • #11 21681966
    Chip Fryer
  • First PCB milling test with 0.1 mm V-cutter
    #12 21681967
    Chip Fryer
  • #13 21681968
    Chip Fryer
  • 0.1 mm V-cut works better than 0.8 mm end mill
    #14 21681969
    Chip Fryer
  • #15 21681970
    Elizabeth Simon
  • Carbide Create works for CNC g-code generation
    #16 21681971
    Chip Fryer
  • Height mapping compensates for PCB warp during milling
    #17 21681972
    Chip Fryer
  • 60° V-cut bit gave best PCB milling results
    #18 21681973
    Chip Fryer
  • FR4 dust extraction recommended for PCB milling
    #19 21681974
    Mike Hibbett
  • Loose Z-assembly inserts causing instability
    #20 21681975
    Chip Fryer
  • Added motor cooling and drilling motor grounding setup
    #21 21681976
    Chip Fryer
  • Z-probe over milled area caused crash
    #22 21681977
    Chip Fryer
  • FlatCam drill files need imperial import
    #23 21681978
    Chip Fryer
  • #24 21681979
    Elizabeth Simon
  • Stepper and probe setup for PCB milling
    #25 21681980
    Chip Fryer
  • Flatcam milling distance used to track bit wear
    #26 21681981
    Chip Fryer
  • Double-sided tape for PCB fixturing on waste board
    #27 21681982
    Chip Fryer
A user acquired a low-cost desktop CNC machine equipped with a 2.5W laser, aiming primarily to automate PCB drilling and milling tasks. The machine was purchased from Amazon (link provided) and required careful assembly, with attention to mounting alignment. Software setup involved installing CH340 drivers, Candle 1.1.7 for CNC control, LaserGRBL 2.9 for laser operation, and Xloader for firmware updates, though firmware flashing encountered initial difficulties. The user successfully generated G-code from PCB designs using TINA software, experimenting with various free tools such as FlatCAM, PCBConverter, Carbide Create, and Inkscape for Gerber to G-code conversion and engraving. Milling tests on scrap and new PCBs utilized different V-cut bits (10°, 20°, 30°, 45°, 60°) and end mills, with the 60° V-cut bit providing the best results for track isolation and routing between IC pins. Depth of cut and track width were critical parameters, with height mapping and Z-probing features of the CNC controller used to compensate for board unevenness. The user implemented hardware modifications including stepper motor fans, a blower for heatsink cooling, and wiring for Z-axis end stops and height mapping probes. Clamping methods evolved from supplied bolts and wing nuts to using Proxxon step-clamps and double-sided Tesa tape for secure PCB fixation. The user noted the importance of dust extraction due to hazardous FR4 dust and recommended personal protective equipment. Bit wear was tracked by monitoring milling distance, with inexpensive Chinese V-cut bits used initially and comparison made to higher-quality UK-sourced bits. Challenges included software compatibility issues with metric units in FlatCAM and the need for iterative parameter tuning. The project demonstrated that a cheap desktop CNC with a 2.5W laser can effectively drill and mill PCBs with proper setup, software workflow, and hardware modifications.
TL;DR: A low-cost desktop CNC with a 2.5 W laser can drill and mill prototype PCBs reliably; one test board milled in 47 minutes. “This board took 47 minutes to mill.” [Elektroda, Anonymous, post #21681981]
Why it matters: It shows hobbyists how to turn Gerbers into clean, drilled boards at home without messy chemicals.
Who this is for: Electronics hobbyists and prototypers asking how to mill/drill PCBs, cut plastic panels, and pick working settings on a budget.
Can a cheap desktop CNC actually drill PCB holes accurately?
Yes. After initial setup, the machine consistently placed holes where expected. Users milled and then drilled boards with alignment verified by test patterns and subsequent full builds. Drilling speed and accuracy improved workflow compared to hand drilling, especially when paired with height mapping and careful X/Y zeroing. [Elektroda, Anonymous, post #21681962]
What bits and settings worked best for PCB trace isolation?
Repeated tests showed the 0.1 mm 60° V‑cutter gave the cleanest isolation. Depth near 0.06 mm with slow feeds avoided over‑widening. It routed 0.5 mm between DIP pins, managed 0.4 mm, and left a faint but conductive 0.2 mm track. “The 60 Degree V‑cut gave my best results.” [Elektroda, Anonymous, post #21681973]
How do I convert Gerber/Excellon files to G‑code for this CNC?
Use FlatCAM to import Gerbers, set tools/parameters, and generate G‑code. If drill positions look wrong, open Excellon files with FlatCAM set to inches while keeping Gerbers metric. This fixes alignment. Alternatives include TINA’s direct G‑code export and Inkscape for engraving paths. [Elektroda, Anonymous, post #21681978]
How do I set up Z‑probe and height mapping in Candle?
Connect the PCB to ground and the spindle/tool to A5. In Candle, Z‑probe to find copper height, zero Z, then create a Height Map over your board area (e.g., ~4 mm grid). Enable “Use Heightmap” before sending the job so Z adjusts during milling. [Elektroda, Anonymous, post #21681972]
What’s a fast, reliable workflow to mill a PCB with consistent isolation?
Three steps: 1) Zero X/Y at the board corner; Z‑probe and zero Z. 2) Create and save a dense height map; enable it. 3) Flood a light cutting oil puddle, mill traces, then drill and cut‑out, re‑probing Z after every tool change. [Elektroda, Anonymous, post #21681981]
How long do typical milling jobs take on this setup?
A representative board milled in about 47 minutes, with total project time near two hours including probing, drilling, and outline cutting. Candle showed 29,232 G‑code lines growing to 30,335 after height‑map compensation, reflecting finer Z control. [Elektroda, Anonymous, post #21681981]
What are practical clamping methods for thin PCB stock?
Use step‑clamps to secure a wasteboard and the PCB, keeping clamps clear of the toolpath. For small boards, adhere PCB to the wasteboard with strong double‑sided tape (e.g., Tesa) and clamp the wasteboard; clip the probe lead to a reachable clamp. [Elektroda, Anonymous, post #21681982]
Can it cut plastic front panels and how accurate is it?
Yes. Multi‑pass cutting in plastic produced a near‑nominal 30 × 20 mm rectangular aperture that measured about 30.3 × 20.2 mm. Use modest feeds, shallow depth‑per‑pass, and keep the laptop awake or the job will halt when USB drops. [Elektroda, Anonymous, post #21681971]
End mill or V‑bit for isolation routing?
V‑bits excel for copper isolation on small machines. A 20–60° V‑bit produced clean trenches; a 0.8 mm end mill “chomped” and over‑cut at 0.09 mm depth. Shallower V‑cuts reduce surface width, protecting narrow tracks. [Elektroda, Anonymous, post #21681969]
How do I avoid trace width loss with V‑bits?
Remember: deeper V‑cuts widen the surface kerf. Keep isolation depth just above copper thickness and adjust track/pad sizes accordingly. Test small patches to tune depth so you don’t undercut adjacent traces. “The deeper you mill then the wider the cut.” [Elektroda, Anonymous, post #21681964]
What cooling and reliability tweaks should I add on day one?
Add a small blower on the driver heatsinks and 30 mm fans on the stepper motors. Monitor motor temps during probing and long jobs. Users noted steppers and drivers ran hot until airflow was added, improving stability over sessions. [Elektroda, Anonymous, post #21681980]
Any gotchas that can ruin bits or stall jobs?
Yes. Unplug the handheld controller or Candle won’t connect. Keep the laptop on AC to prevent sleep mid‑cut. Never Z‑probe on an already‑isolated area or you can snap a bit due to open circuit. Install an accessible STOP button. [Elektroda, Anonymous, post #21681961]
What materials and PPE should I use for safer PCB milling?
Use FR1 when possible to reduce glass dust. If milling FR4, provide local extraction and wear a P3 respirator. Flooding light cutting oil helps trap swarf, easing cleanup with a vacuum afterward. Safety habits matter on small benches. [Elektroda, Anonymous, post #21681975]
How durable are low‑cost V‑bits in practice?
Tracking mileage in FlatCAM showed a single budget V‑bit beginning to dull after over 25 m of milling travel. Since bits cost about the price of coffee, keep spares and track usage per material (FR1 vs FR4) for predictable swaps. [Elektroda, Anonymous, post #21681981]
What software stack has worked end‑to‑end on this CNC?
Design in TINA or your PCB CAD, export Gerber/Excellon, prepare toolpaths in FlatCAM, then run G‑code in Candle. For engraving panels, Inkscape can export G‑code directly. Carbide Create helps design simple cutouts and pockets. [Elektroda, Anonymous, post #21681966]
Does the included 2.5 W laser help with PCB work?
It’s bundled but was not the focus. The thread centers on drilling, isolation routing, and panel cutting with the spindle. Treat the laser as optional until you have a safe, ventilated setup and a clear use‑case. [Elektroda, Anonymous, post #21681956]
