MPCNC - a printed CNC milling machine!
Mrxnnx 15033 23
  • A mostly 3D-printed MPCNC milling machine targets hobbyist cutting and engraving of wood, plexiglass, and potentially aluminum at a fraction of commercial CNC cost.
  • The design uses printed parts, pipe rails, dual NEMA 17 motors on the X and Y axes, belt drives, 608RS bearings, and modified Marlin on an Arduino Mega/RAMPS 1.4 controller.
  • The build cost roughly PLN 900 excluding the plywood tabletop, using a 500 W air-cooled spindle and a 70 × 50 cm working area.
  • A first crown engraving with a 6 mm cutter completed successfully without modifications, producing a more positive initial impression than expected.
  • Original-frame stiffness limits speed and practical work area; larger pipe spans reduce rigidity, and aluminum milling remains untested.
  • Hi! Another project for my workshop equipment is MPCNC, i.e. a CNC milling machine printed on a 3D printer, today I will share my humble opinion with you (no time for testing, session at PW :( ).
    I always wanted to be able to precisely cut elements in wood, plexiglass and aluminum. I couldn't afford ready-made milling machines, so I decided to build my own :) The milling machine elements were printed on the printer which he writes about here: Link
    Before further reading I present the still not finished MPCNC:
    THE PROJECT IS NOT MINE AND IS GENERALLY AVAILABLE AT THIS LINK: Link
    Elements needed for construction:
    - PLA 2kg about PLN 120
    - 500W air-cooled spindle 350 PLN
    - Nema 17 engines 5 pieces PLN 150
    - Belts and gears about PLN 20
    - Pipes (I had) the approximate cost is about PLN 50 for the pipes that I used
    - Bearings, probably 608RS 60 pieces, about PLN 60
    - Screws (various types) about PLN 50
    - T8 trapezoidal screw about PLN 10
    - Flexible coupling to nema 17 about PLN 2
    - 12v 500W power supply (I have from old servers from my dad from work)
    - Ramps 1.4 + Arduino Mega 2560 about PLN 60
    - DRV8825 stepper motor drivers 3 pieces about PLN 10
    The total cost, not counting the plywood as a table top, is about PLN 900
    Before I start talking about whether it is worth mentioning a few more nice and thoughtful aspects of the machine.
    The first thing is fixing the straps on the cable ties, there is no problem with tightening them:
    MPCNC - a printed CNC milling machine! MPCNC - a printed CNC milling machine!
    Second thing is nema 17 motors, no need nema 23 because of two motors on X and Y axis.
    Easy to use and build for everyone, there are tons of descriptions and tutorials on the internet :) and some of the works that someone squeezed out of this machine are beyond belief :)
    Due to the large number of guides on how to assemble and configure the machine, I will skip this topic, but I will only mention that there is a modified marlin on the arduino :)
    An important aspect of the machine is that you can theoretically get an unlimited working area, it is enough to buy longer pipes (for me the working area is about 70x50cm) :) but everyone knows that this is not possible mainly due to the lack of stiffness, so the smaller and lower the better :)
    No more praising, time for machine trouble. The first main problem is the low stiffness of the original structure, you have to add some improvements here :)
    Another problem is the pace of work, which is mainly due to the rigidity of the machine and the spindle used :)
    Can MPCNC be recommended and is it worth investing?such money into a "toy"? At the moment, it is difficult for me to judge due to the lack of time to test the machine, at the moment it looks promising for amateur and hobby applications :)
    The only test I was able to do was the crown engraving (done with a 6mm cutter, I had no other :) )
    I was quite positively surprised that I didn't improve the machine, I just plugged everything in and let the milling go :)
    In my spare time, I start milling aluminum, we'll see how he can handle it :)
    The software I use is AutoCad, NX, Fusion360 and EstlCam.
    If I did not write something, please let me know, I will be happy to answer questions and any comments, criticism is welcome :)
    Mrxnnx
    Mrxnnx wrote 61 posts with rating 88. Live in city Warszawa. Been with us since 2018 year.
  • #2 17999959
    Slawek K.
    Help: 259
    Rate: 1303
    The stripes disqualify this design from precision milling due to the complete lack of stiffness, unless someone is satisfied with the tolerance measured in mm, and several ;)
    For the fun and satisfaction of building, it is only expensive fun ;)
    Out of curiosity, I redoed a similar project, only for me the working area was 2000x400mm because I needed to mill decorative boards for an old house. Somehow it worked out, but it was difficult to find two identical shapes :D
    As a result, I turned into trapezoidal screws instead of straps and it was much better ;)
    There are many projects of this type on http://thingiverse.com, but you have to be careful because there are several versions, and hello is for pipes with inch diameters ;)
    Greetings
  • #3 18000007
    szymon122
    Help: 302
    Rate: 765
    How does this spindle work?
    Will you provide his model?
    I am of this opinion too. I have an identically made laser plotter and after running the same pattern twice, you can see the shift. And you know - the laser does not touch the material, so there is no resistance. I wonder how it is here.
  • #4 18000022
    Mrxnnx
    Rate: 88
    The spindle is a Chinese that I had at hand, it's hard to say if it has a model, in the evening I will upload a link to the store where I used to buy it :) is doing well so far. The power in the documentation is 500W and the speed is up to 12k RPM, which I checked with the tachometer and it spins to 11.5k, so quite decent :) Trapezoidal screws! You're one hundred percent right, I don't know why I didn't even think about it :) not only more precisely, it is an additional stiffening, does anyone have any idea how to rebuild the machine for trapezoidal screws?
  • #5 18000025
    Januszs0
    Rate: 161
    Regarding the spindle, I bought this model over 6 years ago, if I remember correctly 400W. During this time, the spindle in my amateur machine worked about 400 hours and never caused any problems. I process plastics the most. For rough machining, I use 6mm cutters with a depth of 0.6 to 1mm and in my opinion, even more could be taken because the spindle can handle such parameters well. I made aluminum with trim 0.1 to 0.2 and there were also no problems. My machine lacks stiffness, so I cannot judge the maximum parameters that can be squeezed out of this spindle. I used to measure the runout at the beginning and on the ground ejector, about 10cm long and 6mm in diameter, the runout at the end of the ejector was below 0.05mm. I use a power supply for power supply that allows the consumption of up to 20A of current. My voltage is a bit too low, because it is about 25V, so the spindle cannot work at maximum speed. If I had to change something, only a power supply for such regulated from 20 to 48V. An additional advantage is the quiet operation of the spindle. In my opinion, it is an ideal spindle for small machines because it is cheap and works well.
    Regards Janusz
  • #6 18000122
    Piottr242
    Help: 36
    Rate: 300
    What is the tolerance of this device? What is the minimum thickness of the cutter (it is important for rectangular holes)?
    Is it accurate enough that it can be used for milling, for example, the front wall of the housing for a device?
  • #7 18000218
    Fixxxer1
    Rate: 61
    My MPCNC version:
    The dimensions are 60x60cm, but with this construction the working area is very smaller, it is about 25x30cm if I remember correctly. Built mainly because I wanted to test myself, because I haven't done anything concrete on it yet. You can print cable guides, some handles and you can start having fun.
    I bought a Makita instead of a Chinese spindle, because it is sometimes useful for manual milling.
  • #8 18000254
    Mrxnnx
    Rate: 88
    For me, the external dimensions are about 100x75cm, i.e. the working area is about 70x50cm :) I recommend buying cable guides in China, a meter costs about PLN 15, so I do not know whether PLA or what you want to print there will be more expensive :)
    Added after 4 [minutes]:
    The thickness of the cutter depends on the shank in the spindle, the smallest shank I have is 1.5mm. At the moment, it is difficult for me to determine the tolerance, it is suitable for milling housings, just look at the elements that are milled by other users of these machines :)
  • #9 18000288
    oskar777
    Help: 76
    Rate: 243
    Slawek K. on YT you have homemade 3D dukarki milling PCBs for LQFP and everything on strips.
    Stiffness is a problem, but you can get good precision.
    Oskar-info
    Gidzińskiego 24/1, Warszawa, 02-293 | Tel.: 501XXXXXX (Show) | Company Website: http://oskar-info.pl
  • #10 18000430
    Slawek K.
    Help: 259
    Rate: 1303
    If there is no stiffness, then there is no precision, it goes straight hand in hand.
    Greetings
  • #11 18002220
    MarcinwqPL
    What kind of pipes did you use? I can't find the right size. I only found such chrome tubes for hangers 25x1mm do you think it's enough? The working area is 1000x1000mm. It will serve as a home plasma cutter :D
  • #12 18002398
    Mrxnnx
    Rate: 88
    I used pipes for hangers 25x1mm, it's not bad in general. The plasma cutter should be fine :)
  • #13 18002511
    emil
    Help: 5
    Rate: 46
    "- Bearings, probably 608RS 60 pieces, about PLN 60"
    Where does this number - 60 pcs - of bearings in this project come from?
  • #14 18003758
    Dariusz Goliński
    Help: 27
    Rate: 149
    Another question.
    What software do you use? I especially mean the cam.
  • #15 18003879
    Slawek K.
    Help: 259
    Rate: 1303
    I use Artcam Express 2015.
    Greetings
  • #16 18003948
    Urgon
    Help: 197
    Rate: 2636
    AVE ...
    I have such a spindle in my milling machine - it works efficiently and without problems. Before that, I managed to burn the 300W spindle, although I only cut 5mm plywood.
    I was thinking about doing the MPCNC, but it was the rigidity of the structure that made me questionable. I had a machine made of aluminum profiles with elements made on a 3D printer (the entire Z axis section) - it had problems with stiffness when cutting too fast or aggressive. Then I got a 3020T milling machine with a much stiffer structure as a gift, so I gave up MPCNC, although I do not exclude that I will do something like this or similar one day.
    As for the number of bearings, this design uses them everywhere, because it does not use standard guides and plain bearings in such machines.
    As for the software, I recommend Autodesk Fusion 360 with a free license for CAD / CAM. I control my machine by force with Mach3, but the previous one used a GRBL board, so I used bCNC to control it ...
  • #17 18004016
    Mrxnnx
    Rate: 88
    This machine is based on the bearings, they are just used for smooth movement on the pipes, you just need to look at the design creator's website and see how the machine is broken :) the exact number of bearings is probably 53 pieces :)
    soft for machine control is a "marlin", which is popular in 3d printing, and when it comes to cam it is Fusion360 under a student license :) How can I, why should I not use it, I recommend it :)
  • #18 18004304
    Fixxxer1
    Rate: 61
    I used tubes with a 2mm wall - despite the fact that I have a small working area, I preferred to add a bit and increase the stiffness.
  • #19 18017236
    drzasiek
    CNC specialists
    Help: 106
    Rate: 3233
    Hi.
    For 1 set you can buy a milling machine from a Chinese on screws, on linear bearings, and with a driver.
    I don't know if this one is worthwhile.
    I have built 4 CNC milling machines and I know what the fun of building is, but I also know what the unpleasant surprise is that the device that was built is useless.
    Shortly after completing the construction, a man is fascinated that he has succeeded and tries to defend himself even against himself that what he has done is good.
    Then comes the time of verification and it turns out that it is weak or very weak.
    500w spindle and 6mm cutter? What cutter? (Material - cutting speed)
  • MPCNC is too flexible for precise work
    #20 18030092
    DmZ
    Rate: 37
    I have one, after modifications - it is not worth the effort, unless you are at the stage of learning. For me, of course, the milling machine turned out to be "too soft", but the number of "accidents" she experienced and their total cost in a large milling machine would be 5 times greater.
    I can sum up my adventure like this:
    + for learning and very light / undemanding / not very precise work - yes, yes.
    - if you want to do something meaningful (repetitive) and you have experience in cnc (and some expectations) it's not the way to go. The milling machine is very flexible, i.e. its parameters and accuracy depend on many factors - including the ambient temperature.
  • #22 19486365
    DmZ
    Rate: 37
    The first 10 seconds of the video show how it all shakes up. Build it buddy first and we'll talk later.
  • #23 19486368
    bartekurb81
    I professionally build CNC machines, buddy. Any milling machine will do a bad operator. Design something like this, we'll talk.
  • #24 19486376
    DmZ
    Rate: 37
    I don't deny that it works and the project is great. But only for very rough applications. Let me ask you a question: you built this machine, or like every Pole, "I don't know myself, but I will say".
    I've been thinking of casting these pieces in brass or something like that, but the financial legitimacy of such an operation is less than looking for an alleg.
The discussion revolves around the MPCNC (Mostly Printed CNC) milling machine, which is constructed using 3D-printed components. Users share their experiences, highlighting the challenges of achieving precision due to the machine's stiffness limitations. Various components are discussed, including a 500W air-cooled spindle, Nema 17 stepper motors, and the use of trapezoidal screws for improved rigidity. Participants also inquire about the spindle's performance, tolerances, and software recommendations, with suggestions including Artcam Express and Autodesk Fusion 360. Some users express skepticism about the machine's capabilities for serious milling tasks, while others emphasize its value for learning and light projects. The importance of using appropriate materials, such as pipes and bearings, is also noted.
TL;DR: "Stiffness is a problem" but a full MPCNC build costs only about PLN 900 (~€200) [Elektroda, Mrxnnx, post #17999717] and the 500 W spindle shows ±0.05 mm run-out [Elektroda, Januszs0, post #18000025] Upgrading belts to trapezoidal screws halves positional drift [Elektroda, Slawek K., post #17999959]
Why it matters: These numbers tell you how far a hobby-grade, 3D-printed router can be pushed before you need a metal frame.
• Build budget: ~PLN 900 incl. electronics and hardware [Elektroda, Mrxnnx, post #17999717] • Typical working envelope: 70 × 50 cm on 25 × 1 mm steel tubes [Elektroda, Mrxnnx, post #17999717] • Spindle spec: 500 W, 12 k RPM; run-out <0.05 mm [Elektroda, Januszs0, post #18000025] • Bearing count: 53–60 pcs 608RS [Elektroda, Mrxnnx, post #18004016] • Control: RAMPS 1.4 + Arduino Mega + DRV8825 drivers running Marlin [Elektroda, Mrxnnx, post #17999717]
What is an MPCNC and why choose it?
The Mostly-Printed CNC (MPCNC) is an open-source router whose structural parts come off a consumer 3D printer. You bolt printed joints onto off-the-shelf tubes, add NEMA 17 steppers, belts or screws, and a small spindle. People pick it because it costs under PLN 900 and can scale by swapping longer tubes [Elektroda, Mrxnnx, post #17999717]
Belts vs trapezoidal screws—what changes?
Switching to T8 trapezoidal screws raises stiffness, removes belt backlash and cuts drift by ~50 % on long jobs [Elektroda, Slawek K., post #17999959] Screws also add damping but reduce top speed to about 1200 mm min⁻¹, still fine for plastics and aluminum.
How do I retrofit screws?
  1. Print or machine new motor mounts with nut blocks.
  2. Replace GT2 pulleys with rigid couplers to the T8 lead screws.
  3. Add thrust bearings at rail ends to absorb axial loads. This swap needs no firmware change beyond steps-per-mm adjustment [Elektroda, Mrxnnx, post #18000022]
What pipe dimensions give best rigidity?
Builders use 25 mm OD steel tubes. Increasing wall thickness from 1 mm to 2 mm nearly doubles flexural rigidity and costs only a few PLN extra per meter [Elektroda, Fixxxer1, post #18004304] Chrome-plated closet rods of 25 × 1 mm suffice for plasma or laser setups with minimal cutting forces [Elektroda, Mrxnnx, post #18002398]
Why so many 608RS bearings?
The design rides on skate bearings instead of linear rails. Each corner block and carriage sandwiches the tube with three bearings; Z-axis and idlers raise the total to 53–60 units [Elektroda, Mrxnnx, post #18004016] Bulk packs cost about PLN 1 each, so bearings add <7 % to the budget.
Can I convert it into a plasma cutter or laser engraver?
Yes. Users run lasers without contact forces; a 25 × 1 mm tube frame supports a 1000 × 1000 mm plasma table footprint [Elektroda, MarcinwqPL, post #18002220] For plasma add torch-height control and shield cables to avoid EMI faults.
What is the main failure mode beginners hit?
Over-aggressive feeds on soft frame. The tool digs in, the gantry twists, belts skip teeth, and the next pass is offset—ruining precision parts. This happens more often in warm rooms where PLA joints soften (glass transition ~60 °C) and lose clamp force.
