74LS92 Divide by 12 Counter Not Counting, Outputs Random—Wiring or Pin Setup Issue?
876 13
How do I wire and clock a 74LS92 divide-by-12 counter so it counts correctly instead of giving random outputs?
Wire the 74LS92 with Vcc on pin 5, GND on pin 10, tie MR1/MR2 (pins 6/7) low, connect Q0 (pin 12) to CP1 (pin 1), and feed a clean clock into /CP0 (pin 14) [#21682340] Your jumper wire to +5 V is effectively a bouncing switch, so it creates multiple clock edges and random counts; use a real pulse source such as a 555 astable or a debounced switch instead [#21682343][#21682347] The 74LS92 clocks on the falling edge, so it needs fast, clean transitions, not slow RC edges [#21682348] A capacitor can help with delay, but by itself it may not produce a clean enough edge for LS logic; a Schmitt-trigger gate like 74LS14/74LS132, or a proper debounce circuit, is a better fix [#21682348][#21682351] If you test with LEDs, use a simple LED plus series resistor to verify the outputs once the clock is clean [#21682340]
  • #1 21682339
    david lopez
  • 74LS92 wiring and debounce setup advice
    #2 21682340
    David Ashton
  • #3 21682341
    Chip Fryer
  • #4 21682342
    david lopez
  • Jumper wire bounce causes multiple clock pulses
    #5 21682343
    John Beetem
  • Debouncing switch pulses with a 74LS00 RS flip-flop
    #6 21682344
    PeterTraneus Anderson
  • #7 21682345
    david lopez
  • #8 21682346
    david lopez
  • Switch debounce with 100 kΩ and 0.1 µF RC
    #9 21682347
    David Ashton
  • 74LS92 needs fast clock edges from one-shot
    #10 21682348
  • #11 21682349
    David Ashton
  • Use retriggerable 74LS123 to debounce button input
    #12 21682350
  • #13 21682351
  • #14 21682352
    David Ashton
The discussion addresses issues with the 74LS92 divide-by-12 counter not counting correctly and producing random outputs. Key points include correct pin wiring: Vcc (5V) on pin 5, GND on pin 10, MR1/2 inputs (pins 6/7) tied low, Q0 (pin 12) connected to CP1 (pin 1), and clock pulses fed into /CP0 (pin 14). Using a jumper wire connected directly to the positive terminal as a clock source causes switch bounce, resulting in multiple unintended clock pulses and erratic counting. Clean clock pulses with fast rising and falling edges are essential; a 555 timer in astable mode or a debounced switch circuit using NAND gates (e.g., 74LS00) is recommended. Capacitors can provide debounce delay but do not produce the sharp edges required by the 74LS92 clock inputs, which trigger on the falling edge. Schmitt-trigger gates like 74LS132 or 74LS14 can convert slow input transitions into fast edges. Alternative solutions include using a 74LS123 retriggerable monostable multivibrator for pulse shaping. Proper power supply decoupling with electrolytic and ceramic capacitors near the IC is advised to ensure stable operation.
TL;DR: 74LS92 needs fast edges (~15 ns) and clean clocking; “A capacitor will provide debounce delay, but will not provide the 15‑nanosecond rising and falling edges.” Use a 555, Schmitt gates, or a NAND RS latch, not a jumper wire. [Elektroda, Anonymous, post #21682348]
Why it matters:** This FAQ helps hobbyists fix “random outputs” and get a reliable divide‑by‑12 count on the 74LS92.
How do I wire a 74LS92 so it actually counts by 12?
Power Vcc to pin 5 and GND to pin 10. Tie MR1 and MR2 (pins 6 and 7) low. Connect Q0 (pin 12) to CP1 (pin 1). Feed a clean clock into /CP0 (pin 14). Use proper decoupling near the IC. This yields the intended divide‑by‑12 cascade. [Elektroda, Anonymous, post #21682340]
Why does my output look random when I touch a jumper to +5 V for clock?
Your jumper acts like a bouncy switch, producing multiple unintended pulses per touch. That makes the counter jump states unpredictably. Use a debounced source such as a 555 timer or a NAND‑latch edge cleaner to deliver one clean falling edge per count. [Elektroda, Anonymous, post #21682343]
What edge does the 74LS92 clock on, and how fast should that edge be?
The 74LS92 advances on the falling clock edge. It expects fast transitions—on the order of about 15 ns. Slow RC edges can be interpreted as multiple clocks, causing miscounts. Use Schmitt‑trigger gating or a proper pulse source to ensure sharp edges. [Elektroda, Anonymous, post #21682348]
Can a single capacitor fix switch bounce for the clock input?
A capacitor adds delay but cannot create the fast 15 ns edges the 74LS92 expects. Slow slopes may still generate extra counts. Pair RC shaping with a Schmitt trigger or use a digital debounce (e.g., 74LS00 RS latch) for clean transitions. [Elektroda, Anonymous, post #21682348]
What’s a quick way to generate a slow, clean clock for testing?
Build a 555 astable at 1–2 Hz so you can watch the LEDs step. Decouple the supply and route short clock leads. Avoid pushbuttons or loose wires as clock sources during initial bring‑up. “DON’T use a push button switch.” [Elektroda, Anonymous, post #21682340]
How do I debounce with a 74LS00?
Cross‑couple two NAND gates into an RS latch. Drive each free input through resistors from a SPDT switch, with the common at ground. Each actuation flips the latch once, producing a single clean edge to clock the 74LS92. [Elektroda, Anonymous, post #21682344]
Is a 555 reliable for debouncing a button by itself?
A 555 can retrigger on both press and release unless its timeout exceeds the entire press duration. To avoid double clocks, sample the 555 pulse with a falling‑edge D‑type or consider a retriggerable 74LS123 that stretches through bounces. [Elektroda, Anonymous, post #21682350]
What passive RC values have been suggested for basic smoothing?
Example: 100 kΩ in parallel with 0.1 µF from the pin to ground, and 22–33 kΩ from the pin to +5 V via your touch lead. That yields about a 20 ms time constant, improving stability for manual tests. [Elektroda, Anonymous, post #21682347]
Which Schmitt‑trigger parts help with slow edges?
Use 74LS14 inverters or 74LS132 NAND gates. Their hysteresis converts slow RC waveforms into crisp logic transitions suitable for the 74LS92 clock input. Place them between your RC network and /CP0. [Elektroda, Anonymous, post #21682351]
What LEDs and resistors should I use to see the count?
Use red LEDs with a 220 Ω series resistor to ground on Q outputs for visibility during slow clocks. Keep wiring short and add decoupling to minimize glitches while observing state changes. [Elektroda, Anonymous, post #21682340]
What’s an edge case that still breaks counting even after debouncing?
Very slow or ringing edges can be seen as multiple falling transitions. Even with RC delay, without a Schmitt trigger or latch you may get double clocks. Ensure the final stage feeding /CP0 has fast, monotonic edges. [Elektroda, Anonymous, post #21682348]
How can I get test pulses from mains frequency safely?
Divide line‑frequency logic‑level pulses. Example: start with 50 Hz, divide with 7490s to 10, 5, 1, and 0.5 Hz. In 60 Hz regions, use 74LS92 stages for divide‑by‑6 and 2, then 7490 for 1 and 0.5 Hz. Isolate appropriately. [Elektroda, Anonymous, post #21682347]
What is a 74LS123 and why use it here?
The 74LS123 is a dual retriggerable monostable multivibrator. It outputs a fixed‑width pulse that extends with bounces, ensuring one clean output window. Use its Q or Q̅ to supply a sharp falling edge to the 74LS92. [Elektroda, Anonymous, post #21682350]
Three‑step: how do I bench‑test a 74LS92 reliably?
  1. Wire power: pin 5 to +5 V, pin 10 to GND; add 0.1 µF + 10 µF decoupling near the IC.
  2. Tie MR1/MR2 low; connect Q0 (pin 12) to CP1 (pin 1); add LED+220 Ω on Q outputs.
  3. Feed a 1–2 Hz clean clock into /CP0 using a 555 or Schmitt‑triggered source. [Elektroda, Anonymous, post #21682340]
What’s inside the 74LS92—why is it “divide by 12”?
It cascades a divide‑by‑2 and a divide‑by‑6 stage, a classic from the 7492 lineage. This topology is distinct from the 74LS90 (÷10) and 74LS93 (÷16). Choose the part that matches your divisor and waveform needs. [Elektroda, Anonymous, post #21682344]
Do I need a DPDT switch for the NAND‑latch debounce trick?
A single grounded wire can alternate between the R and S inputs for bench tests. For switches, SPDT wiring works; DPDT isn’t required for the basic RS‑latch method described. [Elektroda, Anonymous, post #21682350]
