How Does the 3-20V MOSFET PWM Trigger Switch Driver Board Work for Beginners?
318 9
How do I connect a frequency generator module to a MOSFET PWM driver board to control a motor or lamp?
Power both modules from a 12V nominal supply, connect the Frequency Generator module’s PWM and Ground outputs to the MOSFET module’s matching inputs, and wire the load across Out(+) and Out(-) [#21682388] To understand how it works, start with an LED and series resistor on the generator output, set about 1Hz and 50% duty cycle, and watch it flash half on and half off; then vary frequency and duty cycle to see the effect [#21682392] After that, add the MOSFET module and a small DC motor, and find the frequency that gives the smoothest speed control when you change duty cycle; one example used about 130Hz [#21682392] At 50% duty cycle, the motor behaves roughly as if it is seeing about half the supply voltage, because PWM controls the average power [#21682392] A small 12V filament lamp can also be used, but it will respond differently from an LED because its filament changes more slowly [#21682392]
  • Request for simple wiring diagrams for PWM module
    #1 21682384
    Michelle OBrien
  • Keep asking why to learn fundamentals
    #2 21682385
    Conrad Mannering
  • Invites beginners to ask follow-up questions
    #3 21682386
    Alan Winstanley
  • PWM as digital-to-analog conversion
    #4 21682387
    PeterTraneus Anderson
  • Wiring diagram for MOSFET PWM trigger board
    #5 21682388
    Julian Edgar
  • #6 21682389
    Michelle OBrien
  • #7 21682390
  • #8 21682391
    Michelle OBrien
  • PWM experiment setup with LED, motor, and lamp
    #9 21682392
    Julian Edgar
  • Invitation to ask follow-up questions
    #10 21682393
    Harriet Cook
The discussion centers on understanding the operation of a 3-20V MOSFET PWM Trigger Switch Driver Board, as featured in Practical Electronics magazine's Electronic Building Blocks series. The module combines a Frequency Generator and a MOSFET driver to control power delivery via pulse-width modulation (PWM), primarily for applications like motor speed control. Beginners are encouraged to start with simple experiments, such as connecting an LED with a resistor to observe PWM duty cycle effects at low frequencies, then progressing to driving small motors to explore speed variation by adjusting duty cycle and frequency. The PWM technique rapidly switches the output between on and off states, with the average power controlled by the duty cycle, effectively performing digital-to-analog conversion. The series assumes some prior knowledge but aims to provide practical, accessible projects using inexpensive off-the-shelf modules. Circuit diagrams and wiring examples are provided to aid hobbyists in assembling and experimenting with the modules. The optimal PWM frequency depends on the load, with around 130Hz suggested for smooth motor control. The discussion emphasizes learning through hands-on experimentation and encourages questions to clarify fundamentals.
