Does Underwater Rising Balloon Generator (SeaPower) Store or Generate Potential Energy?
420 13
Can an underwater rising-balloon system generate more energy than the energy used to compress and raise the balloons?
No—this setup cannot create net energy; it only converts energy you already put into compressing the air into lift, and inefficiencies mean you will get less back than you put in [#21683657][#21683668] If you could use an external source like solar power to compress the air first, the system might serve as energy storage, but it would still need a full energy balance to see whether it is worthwhile [#21683663][#21683668] One reply also notes that the example numbers were wrong: 36 CF at 18 ATM corresponds to 648 CF at 1 ATM, so the claimed expansion/lifting calculations are overstated [#21683667] The balloon and the air in it also have weight, and friction plus compressor inefficiency further reduce the net output [#21683667] In short, the buoyancy comes from displaced water, but the energy behind it is the compressed air you supplied, not a free energy source [#21683657][#21683668]
  • Buoyancy does not create net energy
    #1 21683656
    Thomas Boyce
  • Conservation of energy prevents self-powering balloon generator
    #2 21683657
    David Ashton
  • #3 21683658
    EL GUIMOUR YASSIN
  • #4 21683659
    sam prabhu
  • Claim that stacked submerged containers increase net lift
    #5 21683660
    Thomas Boyce
  • #6 21683661
    gargi12 kafe
    #7 21683662
    Thomas Boyce
  • Energy balance needed for each process step
    #8 21683663
    Richard Gabric
  • Claims bubble expansion could drive generators
    #9 21683664
    Thomas Boyce
  • #10 21683665
    Thomas Boyce
  • Need for full cost and efficiency analysis
    #11 21683666
    Richard Gabric
  • Compressed air volume estimate corrects lift calculation
    #12 21683667
    Elizabeth Simon
  • Energy storage only works if efficiency is high
    #13 21683668
    David Ashton
  • #14 21683669
    Juli Maribell
The discussion centers on the feasibility and energy dynamics of an underwater rising balloon generator concept, known as SeaPower, which uses compressed air injected into submerged balloons that expand as they ascend due to decreasing water pressure. This expansion increases buoyant lifting force, theoretically capable of driving generators. Key principles addressed include the buoyant force equal to displaced water volume minus container weight, cumulative lifting forces from stacked balloons, and the energy required to fill and maintain these balloons. Critical analysis highlights that the system does not generate net energy but rather stores potential energy derived from the initial compression work, subject to losses from compressor inefficiency, friction, and system maintenance. The law of conservation of energy is emphasized, indicating no perpetual motion or energy creation occurs without external input. Suggestions include performing detailed energy balance calculations at each stage, considering costs of construction, operation, and energy distribution, and comparing efficiency against direct use of external energy sources like solar or wind. The concept may serve as an energy storage mechanism rather than a primary energy generator, with practical challenges in deep-water deployment and maintenance. The discussion also notes inaccuracies in volume and lifting force calculations and stresses the importance of rigorous numerical validation.
TL;DR: A cubic foot of water weighs 64 lb, and “The lifting force is equal to the volume of water displaced.” In an underwater balloon rig, buoyancy comes from compressed air you already paid to compress; without external input, net energy is ≤ 0. [Elektroda, Anonymous, post #21683656]
Why it matters: This FAQ helps inventors assess if a rising-balloon ‘SeaPower’ concept can beat losses or serve as energy storage.
Does an underwater rising balloon generator create or store energy?
It converts energy you put into compressing air into buoyant lift, then into mechanical/electrical output. Without external energy input, you cannot get net-positive energy after losses. Use it as storage, not generation. [Elektroda, Anonymous, post #21683657]
How does buoyancy translate to lifting force here?
Each balloon’s upward force equals the weight of displaced water minus the balloon and air weight. Designers often quote 64 lb per cubic foot of water to estimate lift, then subtract system mass. “The lifting force is equal to the volume of water displaced.” [Elektroda, Anonymous, post #21683656]
Where do the claimed “extra” lifting forces come from as balloons rise and expand?
Expansion increases displaced volume and instantaneous lift, but that energy traces back to the compression work done at depth. Summing multiple balloons does not create energy; it partitions the same input with losses. [Elektroda, Anonymous, post #21683657]
What was wrong with the 36 ft³ at 18 ATM expansion example?
At 18 ATM, 36 ft³ of air expands to about 648 ft³ at 1 ATM, setting an upper bound. Intermediate estimates must be lower than 648 ft³, so larger figures overstate lift and energy. [Elektroda, Anonymous, post #21683667]
Is this a perpetual motion machine (PMM)?
No. “Energy cannot be created or destroyed, but only changed from one form into another.” Compression, drag, and conversion losses ensure output is less than input. Any result showing more out than in indicates an error. [Elektroda, Anonymous, post #21683668]
Could I drive the compressor with solar or wind and use the balloons as storage?
Yes, treat the underwater system as energy storage charged by PV or wind. The win hinges on round‑trip efficiency and cost versus batteries, pumped hydro, or other options cited near ~85% benchmarks. [Elektroda, Anonymous, post #21683668]
What losses must I include in an energy balance?
Include compressor efficiency, water drag on balloons and rigging, pulley or gearbox friction, and the weight of contained air. These reduce net shaft output and can flip a design from promising to loss‑making. [Elektroda, Anonymous, post #21683667]
How deep should the system go, and why does depth matter?
Greater depth raises pressure, so air compression work increases while available buoyant expansion grows. One example used 18 ATM at about 594 ft to illustrate scaling, but depth also spikes cost and complexity. [Elektroda, Anonymous, post #21683662]
What makes deep-sea installations hard in practice?
Building, maintaining, and transmitting power offshore is costly. Saltwater corrosion, storms, access logistics, and long cables add OPEX and CAPEX that can erase theoretical gains. Local generation often wins. [Elektroda, Anonymous, post #21683666]
How do I run a quick energy-balance check on this concept?
  1. Compute compression energy to supply the required air at depth.
  2. Estimate mechanical work from the buoyant rise, minus drag and drivetrain losses.
  3. Compare outputs to inputs; if output < input, it cannot self‑power. [Elektroda, Anonymous, post #21683663]
What does “ATM” mean in the thread?
ATM denotes atmospheres of pressure relative to surface atmospheric pressure. For example, 18 ATM means pressure is eighteen times surface level in the example calculations. [Elektroda, Anonymous, post #21683662]
What is a Perpetual Motion Machine (PMM)?
A PMM is a hypothetical machine that outputs more energy than it receives. The thread rejects this as it violates conservation of energy and real‑world losses. [Elektroda, Anonymous, post #21683668]
Could natural seabed gas bubbles power a version of this?
Yes, external bubbles provide an energy source you did not pay to compress. You could harness that flow for generation, though safety and continuity are concerns. [Elektroda, Anonymous, post #21683668]
Who is this approach for, and what problem does it solve?
It targets experimenters exploring mechanical energy storage using buoyancy. The goal is shifting renewable energy across time, not creating energy from nothing. [Elektroda, Anonymous, post #21683657]
