How to Calculate Required kW for 3-Phase AC Motor to Move 240kg at 100mph for E-Bike?
408 7
  • #1 21683876
    usama shafiq
  • Rough 75 kW estimate with load included
    #2 21683877
    Aswinth Raj Balasubramani
  • #3 21683878
    leah melda
  • Clarifying motor power and pole count needs
    #4 21683879
    usama shafiq
  • 12 kW motor and 12 kWh battery estimate
    #5 21683880
    Elizabeth Simon
  • #6 21683881
    Noel Smith
  • #7 21683882
    Noel Smith
  • #8 21683883
    lgooj oidfo
The discussion addresses calculating the required power rating for a three-phase AC motor to move a 240 kg load at 100 mph for an electric bike application. Initial rough estimates suggest considering the total load including the vehicle's dry weight and payload, with a typical power-to-weight ratio of approximately 50 W/kg to achieve 100 mph. For a combined load of around 1500 kg, this translates to a motor power of about 75 kW. However, for the specific e-bike design with a dry weight of 87 kg and carrying capacity of 170 kg (total ~240 kg), a motor rated around 12 kW is estimated to be sufficient. Additional considerations include the motor's nominal power, number of poles for torque requirements, and integration with a variable frequency drive (VFD) for enhanced control. Battery capacity is also critical; for one hour of operation at 12 kW, a 12 kWh battery would be necessary, excluding conversion losses. References to automotive motors from Toyota Prius and Nissan are made as examples of suitable motor ratings. The discussion highlights the need to factor in battery weight, motor weight, and system efficiency in the final design.
