Step up transformer size for 4HP 180V 12.5A treadmill motor from India to US use
348 7
  • #1 21684157
    Tarun Thomas
  • #2 21684158
    Richard Gabric
  • #3 21684159
    Tarun Thomas
  • Use mains VA rating, not motor horsepower
    #4 21684160
    Richard Gabric
  • #5 21684161
    Tarun Thomas
  • 2.5 kVA transformer recommended, but measure actual draw
    #6 21684162
    Richard Gabric
  • Need 120 V grounded 20 amp outlet check
    #7 21684163
    Tarun Thomas
  • #8 21684164
    Richard Gabric
A treadmill motor rated at 4HP, 180V, 12.5A from India (operating on 220V AC, 50Hz) is intended for use in the US with 120V AC, 60Hz supply. Since the motor is DC, transformer sizing depends on the treadmill's mains input specifications rather than motor ratings. The key parameter is the VA rating at the treadmill's power input, typically indicated on the power cord or in the manual. The treadmill plug is rated 10A at 250V, implying a maximum transformer rating of about 2200VA. However, a treadmill requiring 4HP (approximately 3000VA) may exceed typical US wall socket ratings (15A, ~1800VA). A grounded 20A, 120V outlet (providing up to 2400VA) is recommended. A step-up transformer rated at 3000W (3kVA) is suggested to safely power the treadmill, with a 5000W transformer as a higher margin option. Grounded outlets have three pins, and care should be taken not to overload the circuit or run other devices simultaneously on the same line.
