12V DC vs 12V AC Transformer for Homemade Electric Motor Kit Drawing 4A at 200-300 RPM
321 7
  • 12V AC transformer won't run DC motor
    #1 21674063
    Glen Boehm
  • #2 21674064
    Benjamin Michael Tecson
  • #3 21674065
    Chuck Sydlo
  • Need for a cheap 12 V 4 A power source
    #4 21674066
    Glen Boehm
  • #6 21674068
    richard gabric
  • Suggesting a 12V 10A constant-voltage supply
    #7 21674069
    Glen Boehm
  • Measure stalled current and use a rectified transformer supply
    #8 21674070
    richard gabric
The discussion addresses the suitability of 12V DC versus 12V AC transformers for powering a homemade electric motor kit drawing approximately 4 amps at 200-300 RPM. The motor is likely a DC motor, as AC power fails to produce a unidirectional magnetic field necessary for rotation, causing the motor not to run on 12V AC transformers. Brush-type motors may run on AC or DC, but brushless motors require DC power. Common 12V DC "wall wart" power supplies often provide less than 2 amps, insufficient for this motor's 4-amp draw. Higher current DC power supplies, such as those with integrated transformers mid-cable or repurposed printer power supplies, are recommended. Startup (stall) current can exceed running current, so power supplies must handle peak loads without voltage sag. Suggestions include measuring stall current, using switched-mode power supplies (SMPS) with overcurrent protection, or employing a rectified AC transformer or a secondhand battery charger with appropriate current ratings. An example of a 12V 5A AC power supply suitable for LED lighting and security cameras was referenced, as well as a 12V 10A constant voltage power supply from Alibaba for higher current needs.
