Best Low-EMI 6ft HDMI Cable Recommendations and PCB Design Solutions for EMI Compliance
396 6
  • HDMI cable and PCB EMI mitigation options
    #1 21684697
    Mike Nudelman
  • #2 21684698
    dorcas melda
  • HDMI cable acting as an antenna due to shielding
    #3 21684699
    Elizabeth Simon
  • Shielding quality mattered more than cable price
    #4 21684700
    Raul Benet
  • #5 21684701
    Raul Benet
  • #6 21684702
    Maurizio Di Paolo Emilio
  • #7 21684703
    Ashton Marsden
The discussion addresses EMI compliance issues caused by standard inexpensive 6ft HDMI cables, which can fail radiated EMI certification due to acting as antennas. Ferrite beads often provide insufficient mitigation. Shielding quality is critical; well-shielded cables with proper shield termination at both ends reduce EMI emissions. Price does not necessarily correlate with shielding effectiveness. A recommended cable with good EMI performance is the Multicomp MC34945 HDMI to HDMI 2m cable, noted for its shielding quality. The Raspberry Pi supplied HDMI cable is also cited as having decent EMI performance. PCB-level EMI mitigation for HDMI lines is limited; common practices include ESD protection, but common-mode chokes used in USB lines are not typically applied to HDMI. References to EMI fundamentals and HDMI high-speed PCB design guides are provided for further technical insight.
