Best Microphone Circuits for Connecting to RTB2004 Oscilloscope for Frequency Measurement
405 9
How can I measure the frequency of an embedded device's audible alert sounds with an oscilloscope, and what microphone circuit should I use?
For these 261–987 Hz alert tones, a simple microphone plus amplifier board is enough; one suggested ready-made option is the Adafruit mic/amp board [#21685038] Use the microphone at the right distance to avoid distortion, and if the signal is too low, boost it with a low-noise op-amp such as TL081 [#21685033] A cone of absorbent material, such as cork, can help direct the sound toward the microphone [#21685033] Then feed the amplified microphone output into the oscilloscope and measure one full wave period to calculate the frequency using F = 1/T [#21685033]
  • Need a microphone circuit for oscilloscope frequency checks
    #1 21685030
    Saneesin
  • #2 21685031
    Giovanni Di Maria
  • Need an easier way to measure 261–987 Hz tones
    #3 21685032
    Saneesin
  • Using a microphone and TL081 preamp for frequency measurement
    #4 21685033
    Giovanni Di Maria
  • #5 21685034
    Richard Gabric
  • #6 21685035
    jessewalter375
  • Microphone type and test setup questions
    #7 21685036
    Saneesin
  • Request for a simple microphone-to-oscilloscope frequency setup
    #8 21685037
    Saneesin
  • #10 21685039
    Saneesin
The discussion addresses the challenge of measuring audio frequencies generated by an embedded device using an RTB2004 oscilloscope. The device produces alert tones between 261 Hz and 987 Hz, and the goal is to verify these frequencies in assembled production units. Direct electrical connection to the oscilloscope is possible during development, but for assembled devices emitting sound, a microphone-based solution is sought. It is noted that microphones have limited bandwidth (typically up to 16 kHz) and may introduce signal distortion if not used properly. For frequency verification, a good quality microphone placed at an appropriate distance can capture the sound, and the signal can be amplified using a low-noise operational amplifier such as the TL081. Frequency measurement can then be performed by analyzing the waveform period on the oscilloscope. Among microphone types, electret microphones are commonly used for such applications due to their sensitivity and ease of integration. A practical recommendation includes using a microphone amplifier board, such as the Adafruit microphone amplifier (product 1063), which simplifies interfacing the microphone output to the oscilloscope. Alternative approaches like smartphone audio spectrum analyzer apps exist but are not suitable here due to test requirements restricting measurement to oscilloscopes only. Additional setup tips include using acoustic cones made of absorbent materials to direct sound towards the microphone and calculating frequency as the reciprocal of the waveform period measured on the oscilloscope.
