Peugeot 508 Airbag Errors B1003 & U1F00: Secure Configuration Fault, BSI Log + Launch Diagnosis
adrian1v2000 1224 2
  • #1 21701119
    adrian1v2000
    >>19156290
    hi guys i have the same problem on my 508 rxh, vn number: VF38URHC8BL100949
    errors are:
    B1003 B1401 UF100, and not possible to delete them,
    can you please help me with a new file to fix the problem?
    thanks
  • #2 21701632
    citroencx25
    Did you check driver airbag?
  • #3 21703833
    adrian1v2000
    hello, yes i did all seems ok, i have attached the errors. i am baffled about the value pointing to the pasager airbag..could it be the a false reading and instead it is the drivers airbag?
