Electrical Installation in Single-Family Homes: Qualifications, SEP & Company Requirements
camel 62119 17
What qualifications do I need to install the electrical system in a single-family house, and do I need my own company or is SEP enough for later inspection/acceptance?
You do not need your own company to install the wiring in a single-family house, and the physical installation can be done yourself, but for acceptance it must be checked and measured by an authorized person. [#2107277] [#2117147] [#2107263] Several replies state that SEP E or D permissions are enough for the inspection, measurements, and the protocol needed for pickup/acceptance. [#2107263] [#2117147] For commissioning/pickup, some posters also mention building qualifications and supervision by a person with construction/management qualifications, and that the utility may require a declaration or paperwork from such an authorized person. [#2107355] [#2107482] [#2117147]
  • #1 2107060
    camel
    Rate: 21
    What qualifications do you need to have to set up an electrical installation in a single-family house, you need to have your own company or not, SEP - is it enough? Of course, that this installation would be picked up by the supervision later.
  • #2 2107263
    apistograma
    Rate: 18
    SEP permissions up to 1kV but for INSTALLATION of the installation. After the installation is done, you need to take measurements. If you have permissions for measurements, you can do it yourself, if not, you can outsource it to someone authorized.
  • #3 2107277
    ekaand
    Help: 37
    Rate: 165
    You do not need any permissions to install the installation at home. To receive the supervision, the measurements must be signed by a person with permissions for measurements and building permits.
  • #4 2107289
    avatar
    Level 36  
    Help: 159
    Rate: 415
    none? and something seems to me that you are not right
  • #5 2107355
    Enpro
    Help: 39
    Rate: 97
    For pick-up at the ZE, you need a declaration of an authorized person for the performance, you can do it yourself, and you can be raised and checked by such a person, and measurements of the effectiveness of zeroing and insulation resistance measurement issued by a licensed person, otherwise you will not change from the building tariff to the target tariff in the ZE. To collect the building, you need a paper from the power supply about the acceptance of the connection to the building, measurements and an entry in the building supervision inspector's book.
  • #6 2107482
    lechm56
    Help: 112
    Rate: 368
    Gentlemen.
    1 Project. (permissions)
    2 Notification in the energy company
    3 execution. (Permissions for assembly and measurements)
    4 Pick-up (by ZE).
  • #7 2108021
    ekaand
    Help: 37
    Rate: 165
    The key issue is whether it should be a house installation or a connection? If only at home, i.e. behind the counter, then as I wrote above.
    Nobody answers such an installation, needless to say, that in order to do a correct and safe installation, you need to have the appropriate knowledge.
  • #8 2108092
    ImPuLs
    Help: 64
    Rate: 36
    It is as it says 'ekaand'.
    Well, unless you come across such receivers from ZE that will make a needle, a pitchfork.
    It has permissions up to 15kV, but I have already done a few installations and no one asked me about them. What's more, the recipient did not even ask who was doing the installation.
    The measurements were usually very good and nobody had any objections to the technical performance.
    It all depends on the ZE, and more specifically on the people who work there.
    The above applies, of course, to pre-measure circuits, without connections.
  • #9 2108289
    HenryK3
    Help: 95
    Rate: 192
    There is no reference to the connection in the question.
    I share the opinion lechm56
    An authorized installer can make a notification for collection at the Power Plant.
    .. and the last 2 sentences of my previous speaker.
  • #10 2114972
    thalex
    Help: 7
    Rate: 42
    I am dealing with the energy sector in this matter;
    I have D and E qualifications in the field of installation and measurements, but the power industry does not want to agree to "submit the installation for acceptance" on my own, explaining that I do not have a license issued by the power industry.
    It's about installing behind the counter in my newly built house.
    Currently, the construction is completed and the building has been given a number, I wrote an application to the energy sector to change the tariff from C11 to G11 for the answer, I will probably wait about three weeks.
    Notification for pickup at ZE can do authorized installer.
    Could you write more precisely about the permissions it is about?
  • #11 2117147
  • #12 2295519
    Marek Rozenblut
    Rate: 32
    Hello. I would like to propose that the LV installation in a single-family house or flat should be done by a qualified person because:
    a.it is about human life:
    b. equipment that will be connected in such a house certainly costs several thousand zlotys
    c. someone who signs the protocol or entry in the work log takes responsibility
    d. an electrician who performs installations in houses can bring a lot of interesting solutions, e.g. bistable system, motion sensors, surge arresters, reduced voltage, hermetic lighting, ...
    e. the fitter will make the correct phase division calculations.
    And you can still write. If you want to save, it is worth doing it with an electrician friend. Greetings.
  • #13 2296261
  • #14 2297016
    zaspany
    Rate: 27
    For the performance of each installation, the person who performs it should have the appropriate permissions and I will not write about the design, workmanship, and acceptance because everything is ok until a misfortune occurs. For example, the insurance will order the documentation of the building's operation, eg from the metering of the installation, or the prosecutor will not let the public prosecutor through the shock.
    But maybe I don't know myself :)
  • #15 2297241
    humek
    Level 32  
    Help: 170
    Rate: 164
    In general, each of you is right, but someone who does (for himself in his own house) will not "perform trash and will try to get the opinion of a friendly electrician who will make the installation. sockets and other collection points do not require writing a doctorate! rather a result of the lack of attention, the lack of basic security in the form of a long line or other simple and logical things, not mountaineering papers or some other license to dig "at height". ) or other permits issued after paying a correspondingly fat fee !!!! I don't really know what they are doing !! For me it is clear and obvious that if someone wants to do something himself, he will try to do it better than a "flapping" specialist and therefore learn in a given topic. it is already as difficult as what some people write here. It is here how in politics ONLY money counts and that's it.
  • #16 2299769
    prez8s
    Help: 69
    Rate: 334
    Buddy humek, you are right in part, they require too much of these papers, but in electricity it is just like that if you connect something wrong, you can easily lose even your life. I personally think that such a sep exam is worth nothing, the truth is that those who have a pale idea about electricity get it for free in schools (at least it was a few years ago) and they should not touch this topic at all. I know it. I used to go to such a kennel (electrical technical school), more than half of the people who got sep had no idea about electricity. Well, that's life. Also, in my opinion, you can wear sep. Practical knowledge and skills count more than a piece of paper!
  • #17 2300364
    Topolski Mirosław
    Moderator of Electrical engineering
    Help: 355
    Rate: 1624
    kol.prez8s is also partially right, only practical knowledge is gained through years of experience in the profession combined with the knowledge of the principles of operation and the selection of protections, cables, and the use of various solutions. Brand Rozenblut
  • #18 2375596
    Vader124
    Gentlemen!
    From what you write two things emerged:
    1 Do you need permissions?
    2 Can it be done?
    I think that if someone wants to put these cables on his own, he will not risk enlarging the group of angels - and the answer is that you can do it.
    On the other hand, I know about the rights that whether they are needed is written in the laws and ministerial regulations. ZE does not issue any of these papers. And in these papers it says "between the lines" that to connect the meter you need at least one receiver.
    Gentlemen, we live in a country where new pieces of paper are invented, but the constitution does not forbid the use of an electric stove-stove, e.g. in a hall - 2 meters from the meter. So we have an installation that needs to be connected to the network (at least one receiver). Recently, models with a voltage supply of 400V are in fashion. they have to pick up something like that and then you can expand it in your own way.
The discussion centers on the qualifications required for electrical installation in single-family homes, specifically regarding the necessity of having a company or SEP (System of Electrical Permissions). Participants clarify that while SEP permits are essential for installations up to 1kV, actual installation does not require formal permissions if done in one's own home. However, for the installation to be accepted by the energy company (ZE), proper measurements must be conducted and signed off by a licensed individual. The conversation emphasizes the importance of having the right knowledge and qualifications, such as D and E permissions, for safe and compliant installations. It is also noted that while some individuals may attempt installations themselves, professional oversight is recommended to ensure safety and compliance with regulations.
