430-0030A EASTAR Transformer Specifications and Datasheet Information Needed
dariushmohammadi 570 3
  • Small 3 × 3.5 cm APC UPS transformer
    #1 21778478
    dariushmohammadi
    Hi everyone,
    I am trying to find some information about above-mentioned transformer.
    I would appreciate it if anyone could help me with that.
    Thanks,
    Dariush
    AI: Could you please let us know what device or application this transformer is used in?
    It is used in APC UPS.
    AI: Are there any other markings, numbers, or physical details (such as size, pin configuration, or voltage ratings) on the transformer that you can share?
    It is a small transformer (about 150 to 200 mW
    and 3 by 3.5 cm in size).
  • #2 21778640
    78db78
    Help: 1822
    Rate: 3297
    Input voltage: 230V
    Output voltages: 15V with half tapping and 18V
  • #3 21778879
    dariushmohammadi
    >>21778640
    Dear 78db78,
    Thanks for the info. Do you mean that the output has two different voltages, one 15 V and one 18 V, center-tapped? Or is it between 15 V and 18 V?
    Anyway, I will try 15 V to see the result.
    Cheers,
    Dariush
  • #4 21779043
    78db78
    Help: 1822
    Rate: 3297
    >>21778879 I mistook the traffic rather than that.
