Schematic Ideas for Wideband Power Amplifier for Function Generator
dennisauntinen 843 2
  • Clarifying load type and output voltage requirements
    #1 21789606
    dennisauntinen
    Hi, I have been looking for any schematic for a power amplifier for my function generator with little to no luck. I am still a beginner and don't have the knowledge to make one myself. I do understand a bit about how amplifiers work now after tons of research but I can't find any info on how to design a proper current/voltage amplifier that can handle 1 Hz to 30 MHz or if that is too big of a frequency range then split it up to like 3 different amplifiers that together can handle the bandwidth. Discrete amplifiers are all for 20 Hz–20/30 kHz as far as I can find or RF range from 10 MHz–1 GHz. My concept is to build one using high-speed, high slew rate op-amps in cascade or composite so that I can make the most of the bandwidth and slew rate, followed by a Class AB current amplifier stage using a Sziklai/CFP output stage. I haven't bought any high-frequency transistors yet or any op-amps as I am not sure how to do this. I don't trust myself to be able to build it even though I understand almost the whole concept besides VBE multiplier and how I would implement that. I have no idea really how slew rate/GBW etc. work more than that they dictate on the total gain available. I cannot be the only one here that wants more current and a bit higher VPP for my function generator, so I am writing this in the hopes that some others in my seat or someone that knows about this could come together and make a signal amplifier that has a dual-rail ±35–40 V input and similar output but with adjustable current between 0–10 A so that there aren't many things that can't be driven by a function generator.
    Sorry for the wall of text and thanks for reading and maybe helping me with this.
    AI: What kind of load are you planning to drive with the amplifier (for example, is it a specific resistance like 50 ohms, 8 ohms, or something else)?
    The load could be anything, inductive, capacitive, motors, solenoids, transformers, etc.
    AI: Do you need the amplifier to deliver the full ±35-40V output and up to 10A of current at the same time, or are those just the maximum ranges you want available?
    It would be nice to have full 800 W at disposal but lower current than 10 A at full voltage isn't necessary, but at least 2–5 A.
  • #2 21789670
    398216 Usunięty
    Help: 3925
    Rate: 9453
    dennisauntinen wrote:
    frequencies from 1 Hz to 30 MHz
    It would be nice to have the full 800 watts available
    Are you sure you know what you are expecting? For a function generator?
  • Current-feedback amplifiers suit wideband function generators
    #3 21789808
    jarek_lnx
    Help: 4201
    Rate: 6131
    In function generators, I have seen integrated operational amplifiers with current feedback (CFA). These amplifiers not only have a wide bandwidth but also a very high slew rate, so they reproduce rectangular waveforms well. An operational generator typically gives 20Vpp and 200mA of short-circuit current, such a thing is easy to build using the THS3091 as an example.
    I don't know if you can find fast operational amplifiers fed from +/-30-40V. A CFA amplifier can be built with discrete components, but high power transistors are slow.
    Some audio amplifiers have a CFA structure, it is possible that you could get a bandwidth of a few MHz.
    You might be interested in:
    https://sound-au.com/articles/cfb-vs-vfb.htm
    https://www.edn.com/high-voltage-current-feedback-amplifier-is-speedy/
    Current feedback amplifiers have no GBW limitation, the bandwidth hardly depends on the gain. There is also no strong SR limitation.
    A ready-made schematic with the parameters you would want I don't have. I have constructed many unusual amplifiers, as part of my professional work, but your requirements are very high. I would have to study myself during such a project. It's also worth asking on the EEVBlog forum, there are quite a few people with a lot of knowledge there.
