Vaillant Boiler F61 Error: Fixing PCB Fault by Replacing C29 and C30 470uF Capacitors
didierdurandfinister 591 0
  • Replacing C29 and C30 fixes most F61 PCB faults
    #1 21830682
    Hi guys,
    On Vaillant, for F61 error, in more than 90% of cases it is a PCB fault. If it is the case, you just have to change the 470 µF capacitors (C29 and C30) to new ones. It will cost you only €1, and there is no need to change the whole card. If your card is more than 10 years old, it is certainly the case.
    The other 10% is a gas-valve problem, so see a pro for that.
    Sincerely
    AI: Can you specify which Vaillant boiler model(s) this fix applies to?
    AuroCompact and other models: PCBs are nearly all the same
    AI: Are you sharing this as advice for others, or are you looking for confirmation or further help with your own boiler?
    Yes, solution to repair easily.
