Selecline 32182 TV no boot, blinks 5x start and 7x shutdown after MP3394S
vieuxchoub 456 2
  • Measured PSU control voltages on 17IPS11/17MB82S
    #1 21869544
    vieuxchoub
    Hi
    I have a Selecline 32182 TV that does not boot.......... It only blinks five times at the remote startup command and 7 times at the closeup command... Nothing on the screen, no sound... I have changed twice the MP3394S IC on the PSU board with no luck. I have flashed by USB with several firmware with the same result.
    Can you help, please?? @ElektrodaBot
    AI: Can you give the exact board numbers/chassis written on the PSU board and main board (and panel model if visible)?
    PSU: 17ips11
    Main board: 17mb82s
    Chassis: VES315WNDS-01
    AI: What voltages have you measured on the PSU/main board: standby 5 V, 12 V/24 V, BL-ON/DIM, and does the backlight or screen flash for a second when you try to start it?
    No backlight flash on startup, no logo, no image visible with an external light
    12 V always present
    stby at 3.3 V
    bl-on at 5 V
    dim at 2 V after pressing power on the remote
  • Check LED output and T-CON fuse voltages
    #2 21869555
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    vieuxchoub wrote:
    Hi
    I have a Selecline 32182 TV that does not boot......... It only blinks five time at the remote startup command and 7 times at the closeup command... Nothing on the screen, no sound... I have chang...
    The most likely fault is not the MP3394S itself, and probably not the USB firmware.
    For this Vestel set (17IPS11 + 17MB82S + VES315WNDS-01), your measurements suggest:
    - 12 V present -> PSU main rail is alive
    - 3.3 V standby -> this is normal for the logic section on many Vestel boards, so the earlier “it should be 5 V” diagnosis is not reliable here
    - BL-ON = 5 V -> the main board is actually asking for backlight
    - DIM = ~2 V -> brightness command is present
    - No backlight flash at all
    - No picture even with flashlight
    So the TV is at least partially booting and sending the enable commands. That shifts suspicion to:
    1. open/failed LED strips in the panel,
    2. LED boost section on 17IPS11 other than MP3394S,
    3. panel/T-CON supply missing,
    4. wrong panel data / corrupted SPI contents on 17MB82S.
    What I would check next
    1) Measure the LED output on the PSU during power-on
    Measure directly on the LED connector coming from the 17IPS11.
    Do this carefully:
    - meter on DC volts,
    - probes on LED+ and LED-,
    - turn TV on.
    Possible results:
    - Voltage rises briefly to a high value and then collapses
    -> classic open LED strip / bad LED(s) inside the panel.
    - Voltage never rises properly
    -> LED driver section on PSU is still not working:
    - boost diode
    - MOSFET
    - current-sense resistors
    - output filter capacitor
    - feedback path / OVP components
    - bad soldering around the LED driver area
    This is the single most important next measurement.
    2) Check whether panel/T-CON power is present
    Since you also have no image with flashlight, do not assume it is “only backlight”.
    Check the T-CON fuse (or panel supply fuse near LVDS connection):
    - TV ON
    - measure both sides of the fuse to chassis ground
    Expected usually:
    - about 12 V on both sides, sometimes another panel supply depending on version
    Interpretation:
    - 12 V on one side, 0 V on the other -> blown fuse
    - 0 V on both sides -> main board is not enabling panel power
    - correct voltage on both sides -> panel is being powered, continue with LVDS/panel-data suspicion
    3) Do not rely too much on the blink count
    On Vestel sets, the front LED often blinks during boot/shutdown sequences and this is not always a meaningful fault code by itself.
    So 5 blinks on startup and 7 on shutdown is not enough to conclude a specific board failure.
    Why replacing MP3394S did not help
    The MP3394S is only the controller for the LED backlight boost/current driver. If:
    - one LED strip is open,
    - one LED is open,
    - boost MOSFET is bad,
    - boost diode is open/leaky,
    - current-sense resistor changed value,
    - LED output has bad solder joints,
    - OVP feedback is wrong,
    then a new MP3394S will behave exactly the same: it will try to start and then shut down.
    So replacing that IC twice without measuring the LED output waveform/voltage usually does not solve the real problem.
    About the firmware
    USB firmware flashing on 17MB82S helps only if:
    - the set still has a working bootloader,
    - the file matches the exact main board + panel option,
    - SPI/NAND contents are not too corrupted.
    A wrong or mismatched firmware can give:
    - no picture,
    - wrong LVDS mapping,
    - no panel start,
    - wrong backlight behavior.
    So firmware is still possible, but because BL-ON and DIM are present, I would first rule out hardware:
    - LED strips
    - LED driver power stage
    - T-CON/panel supply
    Only after those checks would I go deeper into SPI dump compatibility.
    Most probable fault ranking
    Based on your data, I would rank them like this:
    ProbabilitySuspected faultComment
    HighOpen LED strip(s) / failed backlight LEDsVery common on Vestel 32" sets
    High17IPS11 LED driver stage fault outside MP3394SMOSFET/diode/sense/OVP path
    MediumPanel power/T-CON supply missingExplains no visible image
    MediumCorrupt or wrong SPI firmware/panel configEspecially after trying several firmwares
    LowerMain CPU completely deadLess likely, because BL-ON and DIM are generated
    Practical next procedure
    Please perform these 3 measurements and report them:
    A. LED connector voltage
    - standby: LED+ to LED-
    - at power-on: does it jump? to what value?
    - then what value does it settle at?
    B. T-CON fuse voltage
    - measure both sides of fuse to chassis ground with TV ON
    C. PSU connector pin voltages with cable connected
    Report exact voltages for:
    - 12V
    - 3.3V STBY
    - BL-ON
    - DIM
    - any PANEL_VCC / VCC_LCD / ON-OFF pin if present
    If you want the shortest diagnosis
    My direct answer:
    With BL-ON = 5 V and DIM = 2 V, the main board is commanding the backlight, so the fault is most likely in the backlight chain (LED strips) or in the 17IPS11 LED driver power stage, not the MP3394S IC itself.
    Because you also have no image with flashlight, you must additionally verify T-CON/panel supply voltage before blaming firmware.
    What I need from you now
    Please send:
    1. Voltage on LED output during startup
    2. Voltage on T-CON fuse
    3. A clear photo of the 17IPS11 around the LED driver section
    4. If possible, the exact suffix of the boards:
    - 17IPS11-?
    - 17MB82S-?
    With those values I can tell you whether to:
    - open the panel and replace LED strips,
    - continue repairing the PSU LED section,
    - or go back to the main board / SPI firmware route.
  • MP3394S LED output spikes to 80 V, iSense stays at 0 V
    #3 21869849
    vieuxchoub
    Thanks a lot for your detailed answer!!!!
    I have tested the LED strips without opening the chassis, with a Chinese LED tester and the backlight lit up correctly as soon as I connected its pins onto the chassis connector........
    The voltage on the LED connector of the chassis spikes at around 80 V at startup and then decreases slowly; the same at the LED pin of the MP3394S which should return the voltage to the ground..... A jumper between the LED pin of the MP3394S and the ground did not light the backlight neither......I have measured the iSense pin of the MP3394S which stays at 0 V.....
