Kemppi MinarcTig Evo 200 HF failure: 0V at X1, Z001 not powering A002
ELECSOUD 687 6
  • Need wiring diagram to test HF board transformer
    #1 21894010
    ELECSOUD
    I have a problem with a 2012 Kemppi Minarctig Evo 200
    HF is no longer working, lift welding works, however
    After disassembly, the HF board A002 seems OK. However, I am finding 0 V at terminals X1. When I weld in lift mode, it rises to around 5 V.
    The problem seems to be coming from the main board Z001, which is not properly powering the HF card..
    Have you ever had this type of problem?
    Thanks
    Can you specify exactly where you measured the 0 V / 5 V at X1 (on A002 or on Z001), and in which condition: HF mode selected, torch trigger pressed, gas preflow, trying to strike arc, etc.?
    Measurement of 0 V on X1 on A002 with HF mode selected, trigger pressed, attempting to initiate arc, no welding arc
    Measurement of 5 V on X1 on A002 with HF mode selected, trigger pressed, touch ignition, welding arc lit
    Have you already checked the supply path from Z001 to A002: fuses, connector/cable continuity, visible damage or burnt parts, and does the machine show any error LED/code when HF should start?
    No error code, I can't find the wiring diagram to test the transformer that powers the HF board
  • No IGBT gate pulse supply detected
    #2 21894447
    SQ5AZP
    Help: 238
    Rate: 477
    >>21894010 Unplug the connector leading from the HF board to the HF trafo and measure the voltage on it. It should be between 300-450V and disappear as the HF arc terminates.
    Plug the connector into place. Unplug this from the Z001 board to the HF board and measure the voltage during the initiation of the HF arc (should be about 80V.)
    If you have voltage at both points - you have no IGBT gate pulse supply.
  • Z001 power supply likely fault, not HF board
    #3 21894870
    ELECSOUD
    I performed the tests you suggested.
    • With the connector from HF board (A002) to HF transformer unplugged, I measure 0 V (instead of 300-450 V).
    • With the connector from Z001 to HF board unplugged, I also measure 0 V during HF arc initiation attempt (instead of ~80 V).
    So I get 0 V in both cases.
    Does this mean the problem is on the main board Z001 (power supply section for the HF)?
    Is the only realistic solution to replace the Z001 board, or are there other components I should check before?
    Is this a recurring problem on MinarcTig?
    Thank you very much for your help.
  • #4 21895092
    SQ5AZP
    Help: 238
    Rate: 477
    >>21894870 The board is not generating a waveform with HF included. Try restoring the factory settings. And one more thing - the relay on the HF board connects? Because I had forgotten about it.
  • #5 21895159
    ELECSOUD
    I've already tried resetting it, without success.
    Yes, the relay on the HF board is properly connected.
  • #6 21895564
    SQ5AZP
    Help: 238
    Rate: 477
    >>21895159 But does it switch when starting the HF? And most importantly - does it connect? It happened to me several times that the relay "clicked" but did not short-circuit the contact. The relay operates on a DC current of considerable amplitude and there is a slow oxide burn and products of the arc on the contact material.
  • #7 21896161
    ELECSOUD
    The relay was clicking, so I hadn't tested it.
    I tested it and the relay is indeed faulty.
    I'm going to replace it.
A 2012 Kemppi MinarcTig Evo 200 had a failed HF ignition function while lift welding still worked. Measurements on the HF path showed 0 V at X1 on the A002 HF board during HF start attempts, and also 0 V on the Z001-to-A002 supply path where about 80 V was expected. Factory reset did not help. After checking the HF board relay, it was found that the relay clicked but did not actually switch/close reliably, indicating a faulty relay contact. The issue was traced to the HF board relay rather than the main Z001 board, and the relay was to be replaced.
