Canon MF8180c stuck in Download Connected - need Service Support Tool 3.31/3.32
johncopy 486 1
  • Power bump likely interrupted firmware update
    #1 21894210
    johncopy
    I have a Canon MF8180c that is stuck in Download Connected mode. According to AI, I need the support service tool version 3.31 or 3.32 to reset it. Do any of you have this? I've tried newer and older versions of the tool to no avail, so these specific versions are needed.
    What exactly happens when you try the newer/older Service Support Tool versions—does the printer not get detected, do you get an error message, or does the reset run but the MF8180c stays on “Download Connected”?
    The printer is not detected.
    How did it get stuck in “Download Connected” in the first place—were you doing a firmware update, entering service mode, or trying some other reset/service procedure beforehand?
    Power bump
  • #2 21912986
    freshifity
    Unfortunately, the machine is already unsupported. The firmware is no longer available. The service support tool alone will not do anything, you still need the firmware file itself.
    To be scrapped.
