ESP32-S3-DEV-KIT-N8R8 w Arduino IDE - jak podzielić zadania na 2 rdzenie?
Midlle 477 2
  • Clarifying board, IDE, and FreeRTOS performance issue
    #1 21911533
    Midlle
    Hello colleagues,
    i recently encountered a problem with computing power when programming the ESP32.
    I found out that the basic Arduino IDE only uses one of the two available CPU cores, so I tried to work around this using the freeRTOS libraries, but with poor results. Does anyone have a way to distribute tasks well in the program and "unlock" the second CPU core?
    What exact ESP32 module/board do you have and what version of the Arduino IDE and "ESP32 by Espressif" package are you using?
    What specific tasks do you want to distribute between cores and what exactly do you mean by "poor performance" - do you have any bugs, resets/watchdogs, or just a lack of performance improvement?
    No performance improvement or even a decrease in performance.
  • #2 21916841
    efi222
    Help: 12
    Rate: 1219
    Midlle wrote:
    I have tried to work around this using the freeRTOS libraries, but with poor results
    What do you mean "poor results"?
    I sometimes use two cores and it works rather well.
  • Use pinned tasks and avoid shared-resource contention
    #3 21917849
    capacitynmw
    Why You're Not Seeing Performance Improvement
    Wrong API — xTaskCreate() doesn't pin to a core. Use xTaskCreatePinnedToCore() and explicitly assign core 0 or 1.
    Shared resource contention — If both cores access the same variable, I2C, SPI, or Serial without a mutex/semaphore, they block each other → slower than single core.
    Oversized critical sections — portENTER_CRITICAL() or taskENTER_CRITICAL() disables interrupts on both cores. Keep them tiny.
    Too fine-grained tasks — If each task runs for <1ms then yields, context-switch overhead kills parallelism.
    delay() in tasks — Use vTaskDelay() instead; delay() busy-waits.
