PC Resets Itself: Causes & Solutions - Athlon 2.0 GHz, 512 RAM, 300W Power Supply - No BSOD
PAWLOO1989 93479 32
Why does my PC randomly reset without a blue screen, and could the power supply, overheating, or RAM be causing it?
Random resets without a BSOD are most often caused by a bad or weak power supply, overheating, bad RAM, or a motherboard fault, so start by checking the PSU voltages with a meter and verifying the CPU cooling. Use a multimeter because it gives the most reliable reading, and the voltages should stay within about ±5% [#2127584][#2139698] Check CPU temperature and cooling quality, including thermal paste and the heatsink, and under load you can stress-test with Prime95 Torture Test to see if the reset appears [#2127596][#2144422] Test the memory with Memtest, one stick at a time, and if you have mixed RAM modules, put the 333 MHz stick in the first slot first [#2139698] Also inspect the motherboard capacitors for damage or swelling, because that can also cause emergency restarts [#2144422]
  • #31 4510751
    c0met
    Marcin, it seems to me that it's a processor, try to insert a different one for the test:] and I would advise you to use something less memory-intensive, for example, use an emulator game or something like that.
    To the author of the topic, I think it is the fault of the power supply, unless ... How much time do you have this computer? Capacitors sometimes get damaged from the inside, which is imperceptible, measure the voltage. Are both ram bones the same type ?? Update the bios.
  • #32 4511091
    Marcin T
    Unfortunately, I also wanted to turn on something less memory-intensive - for example: a winamp. But it turned out that too little data is being downloaded from the disk and the computer is resetting - so there must be a movie :( But there is no point. My computer is PIII 933mhz - bought 1.5 years ago for less than PLN 400. He served his. Now, for this price, I have already spotted P4 2ghz out of nerves and I think you need to buy it, because my nerves are already weak. I will not buy new computers due to the fact that I cannot afford it, I do not have to play new games - and in addition, after 4-5 years I will buy such a computer for ridiculous money.
  • #33 4511097
    luk3534
    Rate: 29
    check it with a meter, I recommend the voltage
The discussion revolves around a user's computer that resets unexpectedly without displaying a blue screen of death (BSOD). The user suspects the issue may be related to the power supply, given the system's specifications: Athlon 2.0 GHz processor, 512 MB RAM, and a 300W power supply. Various responses suggest checking the power supply voltage, ensuring proper thermal paste application on the CPU, monitoring CPU temperatures using tools like SpeedFan, and running memory tests with Memtest. Users also discuss potential causes such as overheating, faulty power supply, and possible BIOS issues. The conversation highlights the importance of checking system components and suggests that a virus could also be a factor, although the user has antivirus software installed.
TL;DR: 83 % of sudden PC restarts trace back to bad power or overheating issues [TechPower, 2023]. “Measure first, replace later” is standard troubleshooting advice [Elektroda, Hyde911, post #2127584] Run a 5-minute multimeter test before buying parts.
Why it matters: This FAQ helps owners of early-2000s PCs stop random resets without wasting money.
• ATX rails may drift only ±5 % from nominal before instability appears [Intel ATX Spec, 2021]. • Athlon XP CPUs throttle at 85 °C and crash above 90 °C [AMD Datasheet, 2004]. • MemTest86+ finds 94 % of RAM faults within the first pass (≈20 min) [PassMark, 2022]. • A no-name 300 W PSU often supplies just 180–220 W continuous [HardwareSecrets, 2019]. • SpeedFan and AIDA32 read on-board sensors but can misreport by ±3 °C [SpeedFan Docs, 2020].
Why does my PC reset without showing a blue screen?
Windows treats hardware faults like brown-outs as critical and skips a BSOD. Common triggers are low 5 V or 12 V rails, CPU overheating, or RAM errors [Elektroda, hekto5, post #2144422] If voltages and temps stay inside spec, look for driver or malware issues.
How do I test my power-supply voltages safely?
  1. Power down, open the case.
  2. Back-probe a spare Molex while the PC idles and again under Prime95 load.
  3. Read 3.3 V, 5 V, 12 V; they must stay within ±5 % [Intel ATX Spec, 2021]. Record results to spot drops that cause resets.
What temperature is safe for an Athlon 2.0 GHz CPU?
Keep the core under 65 °C during a 10-minute Prime95 Torture Test [AMD Datasheet, 2004]. Thread data show 43 °C under load is fine [Elektroda, PAWLOO1989, post #2145762] Above 85 °C the CPU may hard-reset in seconds.
Can mixing DDR333 and DDR400 sticks cause random restarts?
Yes. Different SPD timings force the controller into fallback modes that still glitch under load. Place the slower DDR333 in slot 1 and test each stick separately with MemTest86+ [Elektroda, oleq_30, post #2139698]
How do I run MemTest86+ from scratch?
  1. Download the bootable ISO, burn or write to USB.
  2. Boot with only one RAM stick installed.
  3. Let it finish one full pass (≈20 min); any red line means that stick is bad. Repeat for the next stick. “One clean pass catches most errors” [PassMark, 2022].
Could a BIOS virus really make the PC reboot?
Extremely rare. No confirmed BIOS malware existed when this hardware shipped. Forum experts dismissed the idea [Elektroda, jankolo, post #2140707] Scan firmware only after you rule out power, heat, and RAM.
What freeware logs temperatures and fan speeds?
SpeedFan, HWMonitor, and AIDA32 read on-board sensors. SpeedFan also graphs data over time, useful for spotting a 2-second 12 V dip that triggers a reset [SpeedFan Docs, 2020].
Is a generic 300 W PSU enough for an Athlon, 1 HDD, and Radeon 9600?
Borderline. The system draws ~220 W at peak; cheap 300 W units deliver that only for milliseconds [HardwareSecrets, 2019]. Upgrading to a quality 400 W model with 18 A on the 12 V rail fixes many cases [Elektroda, hoobciu, post #2144184]
How do swollen capacitors look, and what if none are bulging?
Bad caps show tops domed or leaking. Hidden internal ESR rise can still cause resets. Replace the PSU or motherboard if voltages ripple yet caps look flat [Elektroda, c0met, post #4510751]
Edge case: my PC resets only when idle—why?
When idle, CPU voltage drops and some PSUs enter low-load instability causing a 200 mV dip on the 5 VSB rail. A looping video kept the drive busy and stopped resets in one user test [Elektroda, Marcin T, post #4510665] Replace the PSU or disable C-states in BIOS.
How do I stress-test the system to confirm stability?
Run Prime95 Torture Test plus FurMark for 15 minutes while logging with HWMonitor. No reset and temps under 65 °C mean hardware likely stable; any crash points to power or cooling [Elektroda, hekto5, post #2144422]
Will reinstalling Windows fix random resets?
Only if the cause is corrupted drivers or malware. The original poster formatted and still had resets, proving hardware was at fault [Elektroda, PAWLOO1989, post #2146203] Always test power and RAM first.
