How to Test Fluorescent Lamp Functionality: Visual Signs and Multimeter Methods
mariuszsz 33803 4
  • #1 2152761
    mariuszsz
    Can anyone tell me how to check if the fluorescent lamp is working?
    Regards
  • #2 2152786
    Orochimaru
    Help: 170
    Rate: 532
    You mean the pipe?
    As far as I know, there must be an electrical transition between adjacent pins. Well, the pipe must be tight, but there is no way to check it.
    The easiest way is to connect to the lamp, but I don't think that's what you're after :)
    Pandor
    Help: 6
    Rate: 8
    As Orochimaru wrote, the easiest way is to measure whether there is a passage between the adjacent pins of the fluorescent lamp, but the more important thing is its tightness, whether the gas inside the tube has not escaped. Because you can easily light a fluorescent lamp cold, i.e. by powering it from two opposite pins. If you see that at the twisted pairs (ends) the fluorescent lamp is quite blackened, it's better to leave it alone, it will shine weaker and there is a good chance that it will fail soon. Electronic ballasts that ignite the fluorescent lamp cold, or such converters for fluorescent lamps powered by a battery, accumulator or other low voltage source (although in this case there are also such converters that require connecting 4 leads, i.e. whole twisted pairs), work well with a fluorescent lamp with burnt-out strands. If you use a traditional fluorescent lamp power supply system (choke and igniter), then a fluorescent lamp with burnt strands is useless.
    Orochimaru
    Help: 170
    Rate: 532
    If you have a plasma lamp or tesla coil, you can check them too :D
  • #5 2303063
    Marek Rozenblut
    Rate: 32
    Hello. But if you colloquially refer to the entire lighting fixture as a "fluorescent lamp", please check first if there is a full power supply. The easiest way is a bulb with a socket (220V).
    If so, then check the igniter. However, if it is a luminaire for two fluorescent lamps and has two starters, the starters should be replaced. It is also worth checking the contacts of the connections in the entire fluorescent lamp and at the end we have a choke.
    The fluorescent lamp itself should be checked by inserting it into the luminaire, as the previous speaker suggested. Regards.
