What do the CCW and CW markings on electric motors mean?
mikszy5 22109 6
  • #1 2263997
    mikszy5
    Hello, what does it mean left and right in these engines
    ENGINE 9V LEFT CCW
    MOTOR 9V RIGHT CW
    It is on this page http://www.magserv.com.pl/index.php?op=1
  • #2 2264042
    justarius
    Hello!
    (link doesn't work for me)
    It's probably about the rotation of the rotor - Ad.1. - counterclockwise, Ad.2. - clockwise - looking at the motor from the side of the shaft exit.
  • #3 2264139
    zerpo
    Help: 50
    Rate: 134
    Maybe it's about:
    CW - ClockWise - Clockwise
    CCW - Counter ClockWise - Counterclockwise clock.
    I GUESS :D
  • #4 2264192
    mikszy5
    I mean, they only spin in one direction?
  • #5 2264887
    bogdan_p
    Help: 525
    Rate: 120
    this type of motors are commonly used in cassette recorders, they have an internal rotation stabilizer, they rotate only in one direction, of course, after removing the stabilizer or changing the motor connections, they rotate in either direction
  • #6 2307133
    bu508
    Help: 5
    In practice, the difference between such motors lies in the brushes. After changing the polarity, such a motor will rotate in the opposite direction from the recommended one, but the brushes will work "against the grain", which drastically shortens the life of such a motor.
  • #7 2309865
    justarius
    ... and changes the commutation.
The CCW (Counter ClockWise) and CW (ClockWise) markings on electric motors indicate the direction of rotation when viewed from the shaft exit side. These motors typically rotate in one direction due to internal stabilizers, commonly found in devices like cassette recorders. Changing the motor's polarity can reverse the rotation, but this may lead to increased wear on the brushes and affect commutation, potentially shortening the motor's lifespan.
