Unlocking Maximum Speed on Jungheinrich Forklift After Panel Tampering
alf25 68458 7
  • #1 2470298
    alf25
    Hello. I would like to ask if anyone has service codes for Jungheinrich forklifts of the so-called frontal . Strangely enough, one of the employees was playing with the switches on the panel and slowed down the trolley to a maximum speed of 5 km/h and now I don`t know how to unscrew it. Please help, Thank you in advance. For more information please email alf25(_at_)gazeta.pl. or forum.
  • #2 2650379
    macgyver4
    Rate: 46
    I suggest authorized jungeinrich service because you can forget about the codes
  • #3 2922301
    manfed
    Rate: 21
    I`m also looking for codes for ETX 125. I also have a problem with this company`s manual truck. The drive engine slows down randomly, the version is too poor (old) for the operator to change something. I don`t know whether to blame the control module for this behavior?
  • #4 2925977
    DarekBytom
    Help: 18
    Rate: 71
    Tell me what error you`re getting and I`ll tell you what`s wrong with it
    Regards.
    I`m sorry, but I misunderstood you, check if you don`t have the snail, i.e. slow travel, turned on, if that doesn`t help, give me the exact type of stroller and its serial number, then we`ll figure something out.
    PS for Jungheinrich there are no service codes, only error codes, but in some strollers there is something called service mode, from which you can change some things, but full options are provided by a laptop with service software where you can change all options.
  • #5 3252612
    CENTURION_ALARMY
    Help: 35
    Rate: 63
    If anything, it`s for those interested
    I repair jungheinrich and still cards, broken electronic ones, flooded ones, broken ones. Warranty + invoice
    0660-140-204
  • #6 3252713
    CZAPLIK
    Help: 5
    Rate: 18
    There are two possibilities, one of which has already been described by a colleague, i.e. a shorted snail button (it does not produce an error). The second possibility occurs only in trucks with a platform for the operator and results from an error in the potentiometers that determine the position of the drive wheel and steering drawbar. After replacing one of these potentiometers, the electronics must be calibrated to interpret it appropriately (even small differences in values result in slowing down to the "turtle" speed and giving an error message. From what the guy from the service said, there is "on-foot" calibration, but he only did it once for four hours. a number of activities must be carried out within a certain period of time, which is not easy). Using a laptop, 20 minutes and the pain is gone (with a coffee break). I know because I replaced a damaged potentiometer (it`s much cheaper from the manufacturer). From what the guy from the service said, lifting the stroller up and moving the drive wheel "manually" or if it jumped up while turning and the drive wheel moved not as a result of changing the position of the drawbar, we have the same effect.
    Added after 6 [minutes]:
    As for the service codes for the dozen or so visits of the service gentlemen during which I was present (during my shift) and I always try to be there, the codes are impossible to get, they are not on the card, they are only in the laptop (there are so many of them) and so far none of them has given me convince yourself to share them. Either they are afraid or they are so loyal or their laptops are secured or they log the devices connected to them.
  • #7 3289854
    CENTURION_ALARMY
    Help: 35
    Rate: 63
    As far as I know, they don`t have the codes themselves and everything is in the computer. A friend of mine got fired from the still service center and there was no service, it was all about replacements
  • #8 17131563
    Baster-b2
    Rate: 47
    I have a JUNGHEINRICH EFG 216 stroller and I have a problem with it.
    Codes 39 and 25 appeared on the display.
    The stroller doesn`t move.
    Does anyone have a description of the error codes?
    Regards
The discussion revolves around troubleshooting a Jungheinrich forklift that has been limited to a maximum speed of 5 km/h due to panel tampering. Users suggest consulting authorized Jungheinrich service for assistance, as there are no service codes available, only error codes. One user mentions the possibility of a "snail" button being activated, which restricts speed without generating an error. Another user highlights issues with potentiometers affecting speed and steering, indicating that calibration is necessary after replacement. Error codes 39 and 25 are also mentioned in relation to a different model, the EFG 216, which is not moving. Overall, the consensus is that professional service or specialized software is required to resolve these issues effectively.
