MAN LE 8.140 (2004) - EDC Indicator Activates & Limits Revs to 1800 RPM: Causes & Solutions
brzozayz 6849 13
Why does a MAN LE 8.140 start normally for a few seconds, then trigger the EDC light and limit the engine to about 1800 RPM?
Most replies point to a damaged injection pump, or specifically the pump control unit’s advance actuator, as the cause of the EDC limp mode [#16302587][#16303964][#16562733] One user reports Texa fault code 82 for the advance actuator [#16562733] The suggested first step is to read the exact fault/monitoring data or blink codes before taking anything apart [#16302587][#16308842] If the pump is confirmed bad, it may need overhaul, and the injectors should also be checked [#16306651] After repair, the whole fuel system should be cleaned from the tank through the pipes, filter housing, and sediment bowl, especially since silver filings were found in the tank before the problem started [#16305410][#16306651]
  • #1 16302576
    brzozayz
    Rate: 137
    Hello, I have a problem with Mańek LE 8.140 2004 after starting the engine after about six seconds. the EDC indicator comes on and limits the revolutions to about 1800. If I turn off and ignite it goes normally, but only these few seconds and it cuts off again after connecting the autocom, it crashes the PSG injection time counter and you can only remove it when the engine is off, when it fires up, then after a few seconds back again. Help.
    saron22
    Trucks specialist
    Help: 308
    Rate: 1604
    Enter the error number that crashes. Man's error no.
    I bet on a damaged injection pump
  • #3 16302611
    brzozayz
    Rate: 137
    This hardware does not show the error number before this description is only CA.
    Added after 45 [minutes]:
    Can you read error blink codes in this model?
    saron22
    Trucks specialist
    Help: 308
    Rate: 1604
    You can read.
  • #5 16303145
    brzozayz
    Rate: 137
    And where is the socket and which bulb to use?
    ROKADI
    Help: 43
    Rate: 194
    Hello, do CA monitoring, definitely a pump, as the colleague said above
    ROKADI - MAN
    Kętrzyńskiego 8, Olsztyn, 10-506 | Tel.: 660-XXX-XXX (Show)
  • #7 16304599
    brzozayz
    Rate: 137
    What exactly is this CA about?
  • #8 16305311
    ROKADI
    Help: 43
    Rate: 194
    Hello, check this monitoring MAN LE 8.140 (2004) - EDC Indicator Activates & Limits Revs to 1800 RPM: Causes & Solutions
    ROKADI - MAN
  • #9 16305410
    brzozayz
    Rate: 137
    I will try the sign code again, maybe it will show something. Last year I noticed a lot of silver filings in the tank and that was probably the beginning. The filter was cleaned and the filter was new, but it caught an error from time to time.
    saron22
    Trucks specialist
    Help: 308
    Rate: 1604
    I am afraid that there will be no need to renovate the pump. By the way, you can also check the injectors. Before assembling the repaired pump, remember to clean the fuel system again, starting from the tank, through pipes, filter housing, and sedimentation tank.
  • #11 16306963
    brzozayz
    Rate: 137
    Today I connected the light to read the error codes and it is like I turn on the test, nothing flashes as it lights up and I turn it off, it lights up for 3 seconds, and if I turn the ignition on and off, it's 1 second, I don't know what's going on.
    ROKADI
    Help: 43
    Rate: 194
    Hello, I have a question is it so difficult to connect a computer and check monitoring gentlemen, it's not the Middle Ages, to check the sign codes, I am sending a description of the error MAN LE 8.140 (2004) - EDC Indicator Activates & Limits Revs to 1800 RPM: Causes & Solutions
    ROKADI - MAN
  • #13 16309962
    brzozayz
    Rate: 137
    tomorrow I will update and try to connect again.
  • #14 16562733
    luka199
    Hello, did I fix the fault? I have exactly the same problem.Texa shows error 82, the advance actuator of the pump control unit.
The discussion revolves around a 2004 MAN LE 8.140 experiencing an EDC indicator activation that limits engine revolutions to 1800 RPM shortly after starting. Users suggest potential causes, primarily focusing on a damaged injection pump and the need for error code diagnostics. The author notes the presence of silver filings in the fuel tank, indicating possible contamination. Recommendations include checking the fuel system, cleaning filters, and verifying injector functionality. Users also discuss the process of reading error codes and the importance of connecting diagnostic tools for accurate troubleshooting.
