Electric heaters. How can you check whether they are operational and what power they have?
uki4 43333 9
How can I check whether an electric heater is working and determine its power?
You can check a heater by measuring its cold resistance and calculating the power from it: the resistance changes only slightly when hot, usually by about 5% or less, so use P=U²/R with U=230 V and the measured R, then subtract a few percent [#3212991] Make sure the contacts are clean, because corroded terminals can give a false reading and may need sanding or filing first [#3212991] If you prefer direct electrical measurement, measure current in series on the AC range and voltage in parallel, then calculate power as P=I×V [#3209395] If you have a clamp meter, you can measure the current without breaking the circuit [#3218717] As a rough operational check, the heater should have no gaps or damage to the housing and it should warm up; its power can also be estimated crudely by timing how long it takes to boil 1 liter of water [#3208597]
  • #1 3208468
    uki4
    Rate: 61
    How can you check electric heaters to see if they are working and what power they have?
    I have an ordinary token, but I don't know which value to check it with.
    Regards
  • #2 3208597
    krzychol66
    Help: 57
    Rate: 125
    They should have no gaps and no penetration into the housing. The attached "for a while" should warm up.
    You can determine the power very roughly by boiling a liter of water "on time".
    You cannot determine the power resistance by measuring it due to its dependence on temperature.
  • #3 3208808
    dasko
    Help: 29
    Rate: 72
    You can measure power by measuring the current flowing through the heater.
  • #4 3209217
    lukiiiii
    Help: 82
    Rate: 392
    and in order not to mess with connecting an ammeter in series, turn off everything in the house, connect the heater and measure the time it takes for the meter to make 3 revolutions, find on the meter's plate how many revolutions it takes to equal 1 KWh, i.e. 1000W consumed in an hour, a little math and you will know how much it consumes In the heater
  • #5 3209349
    uki4
    Rate: 61
    This heater is like a clamp, probably from an extruder, and I want to install one on a pipe, and once an electrician checked the power of the heater and said 1200W, but I don't remember how he checked it with this meter.
  • #6 3209395
    lechm56
    Help: 112
    Rate: 368
    Set the maximum value of the alternating current (A) and connect it in series with the heater. Then set the voltage value (V) and connect it in parallel with the heater.
    P (power) = I (current) x V (voltage).
  • #7 3211967
    goldwinger
    Help: 535
    Rate: 2101
    the problem will arise if you have a cheaper meter because these crappy ones do not have the option of measuring alternating current
  • #8 3212991
    _jta_
    Electronics specialist
    Help: 3212
    Rate: 4258
    You can measure the resistance - although it is measured when cold, and when the heater heats up, it is slightly different,
    slightly larger, but this is not a big difference for heaters - about 5%, for some even less.
    Then you calculate the power using the formula P=U^2/R, U=230V, R is the measured resistance, and subtract a few%.
    Be careful with contact when measuring - usually the contacts are corroded and do not connect at low voltage,
    they need to be rubbed with sandpaper or a file, otherwise they may look burnt.
  • #9 3218717
    dasko
    Help: 29
    Rate: 72
    Unless you have a clamp meter, you can measure the current without connecting an ammeter in series.
  • #10 3218754
    asterix17td
    Help: 17
    Rate: 18
    Well, my friend wrote: I have an ordinary property
To check if electric heaters are operational and determine their power, several methods can be employed. Users can measure the current flowing through the heater or use a meter to track the time it takes for the meter to make a certain number of revolutions, correlating this with the heater's power consumption. Additionally, measuring the resistance of the heater when cold and applying the formula P=U^2/R (where U is typically 230V) can provide an estimate of power, though this may vary slightly when the heater is hot. Caution is advised regarding contact quality during measurements, as corroded contacts can affect readings. For those with clamp meters, current can be measured without direct connections.
