Seeking Locations and Current Pricing for Purchasing Carbite/Carbide
Volfram 138687 50
Where can I buy carbide today, and how much does it cost?
You can buy carbide in garden/chemical stores, welding-material wholesalers, some DIY stores like OBI or Castorama, and online shops; in the thread it is often sold under names like “mole repeller” [#3488971] [#5200160] [#18775663] Reported prices include about PLN 5.86–6 per kg in wholesale packs [#8118336] [#5200160], PLN 6 per kg from another seller [#7986597], and PLN 15 per kg in a later offer [#10028942] One post also mentions a 1 kg can for PLN 10 [#5199714], while a 2020 reply says DIY stores sell it for about PLN 25 per kg [#18775663]
  • #32 6475897
  • #33 6583250
    arek59
    Help: 28
    Rate: 327
    I was playing with carbide myself. Intentional effects and various combinations but unfortunately it is also dangerous to use. You have to be careful, once it ripped a can in half under my foot. I do not recommend making firecrackers.
    Well, that's my experiment :D I used to complain that the mower had little power to mow the grass, it went out, choked. So I decided to put a few pieces of carbide in the gas tank as a nitrating agent :D I started it and the effect was intended until sparks came from the muffler, power and revs increased, but unfortunately, after 2-3 minutes of fun, the piston in the engine ended up breaking off :cry:
  • #34 6726744
    marcin.koz2910
    Help: 91
    Rate: 387
    You can buy carbide at any garden store
    Only sometimes it says Mole Repeller instead of CARBID :P
  • #35 6946958
    kogiel
    Help: 11
    Rate: 44
    And does anyone know how much acetylene can be produced from such a 6cm nugget?
  • #36 6947146
    jankolo
    Rest in Peace
    Help: 1792
    Rate: 587
    If you mean a cube-shaped nugget with a side of 6 cm, assuming a carbide density of 2.22 g/cm3, a technical carbide purity of 85% and a 100% reaction yield, you should get about 140 liters of acetylene.
  • Checking carbide mass and acetylene yield calculation
    #37 6947220
    Futrzaczek
    Help: 538
    Rate: 522
    CaC 2 + 2H 2 O -> C 2 h 2 + Ca(OH) 2
    We have a given amount of CaC 2 , we are looking for the quantity C 2 h 2 .
    A lump with a diameter of 6 cm has a volume of 37.7 cm3, or a mass of 83.7 g. Thus, such a nugget contains 1.3 moles of this substance. We also get 1.3 moles of C 2 h 2 , i.e. 29dm3 of acetylene or 39g of this sympathetic gas.
    John - where did I go wrong? Our results differ by more than a factor of four, and I assumed 100% carbide purity...
    F-TECH Michał Kurzela
    Zacisze 20B, Serock, 05-140 | Company Website: https://elektronika.top/
  • #38 6947239
    jankolo
    Rest in Peace
    Help: 1792
    Rate: 587
    jankolo wrote:
    a cube of side 6 cm
    Can you see the difference?
  • Calcium carbide is not a nitrating agent
    #39 6947820
    grzesiekw12
    Help: 47
    Rate: 73
    So I decided to throw a few pieces of carbit into the gas tank as a nitrating agent
    What kind of crap are you typing here. Hello, wake up and stop fantasizing. Complete your elementary school knowledge as soon as possible. It is spelled carbide, not carbit or other flowers of the Polish language.
    Calcium carbide is not a nitrating agent!!!
    And the explosives that can be obtained from it are acetylene mixed with oxygen or some kind of halogen, and metal acetylide.
  • Carbide source and gassing method for mole control
    #40 6948750
    orzechowiec13
    The manufacturer of carbide ensures that 305 liters of acetylene can be produced from one kilogram.
    You can buy carbide in retail or wholesale at: http://www.karbid-sklep.pl
    The product is packed in a sealed bucket that contains 1 kilogram of carbide and allows for long-term storage.
    The mole's burrow consists of a nest, pantry, living, running and feeding corridors, the total length of which may exceed even 200 m, therefore only gassing is a fully effective method to get rid of the pest. Moles are almost blind, but they have a sensitive sense of smell, which is why we can use carbide, which, in reaction with water, emits an unpleasant and repellent smell. The mounds should be trampled, and then put some carbide into the newly formed ones and then cover the hole to prevent the gas from going outside, pour water.
    The smell of carbide irritates the sensitive sense of smell not only of moles. Thanks to it, we can also get rid of water vole, vole and field mouse from the plot.
  • #41 7102838
    scalak4
    Help: 15
    Rate: 39
    hero1521 wrote:
    Hello!
    I have a question, is it possible to buy carbide in the vicinity of Chojnice or in Chojnice itself? If so, how much and where?
    You can buy carbide in Chojnice on the industrial street. The TEMIS trade and service company is located there. It deals with welding and technical gases. Regards. Ps. I also do pyrotechnics.
  • Carbide chemistry and severe acetylene explosion hazards
    #42 7567304
    fuxseb
    Rate: 9
    As I deal with pyrotechnics and chemistry in general for a long time, I inform everyone:
    - we write carbide
    - carbide is calcium acetylide with the formula CaC2
    - its smell is mainly due to the content of calcium phosphide, which forms highly toxic phosphine with water
    - carbide, after adding water, hydrolyzes according to the equation:
    CaC2 + 2H2O -> Ca(OH)2 + C2H2
    This reaction is exothermic, meaning it gives off heat. Calcium hydroxide (slaked lime) and ethyne (acetylene) are formed.
    Now let's deal with the highlight of the show, acetylene.
    - with a content of 2.4% - 83% vol. forms an explosive mixture in the air
    - it is lighter than air
    - in the air it burns with a sooty flame, when mixed with air or oxygen it explodes
    - above 0.2 MPa (about 2 atmospheres) detonates without air, decomposing to primary factors, therefore it is stored in the form of a solution in acetone
    But how do we play it? I immediately say that you can lose your hearing, eyesight, a few fingers or a hand, and if we have no moderation and exaggerate with dimensions, you can even lose your life. That's why I don't recommend this game. Well, the whole idea is to put a small lump of carbide in a liter paint can with a small hole in the bottom. Then a little water is added, the lid is closed and directed in a remote direction. Then we place ourselves perpendicularly to the axis of the box lying on the polygon. It is best to have earplugs in the ears and protective glasses that will provide the appearance of safety. Then I do not recommend putting a lit match to the hole in the bottom, but if you want to... The mixture of acetylene with air will explode violently, creating an unbearably loud bang and throwing the lid several meters away, and the can a little less. Depending on the proportions, it can also shred the can, and the can will us, if we don't have to be satisfied with "earning" a piece of sheet metal on the head.
    To those who want to try KMnO4 with different substances - warning! Most of the mixes on this are pyrophoric when combined with water. Especially sugar, it acts almost like permanganate with glycerin. It's the same with metals, only there's no smoke and then fire, but first the flash that will make a roast chicken out of any man, then the smoke ;)
    If you want to know where to buy various things like fuses or reagents, I can recommend a few sellers, but I don't know if I can advertise them here, so let's say this is my friend's website from another forum: link .
    @fymon123 You can see the effects of being hit in the head with a can in your youth. Unspelling, ungrammatical, incomprehensible. Don't play with it or you'll hurt yourself even more. Yes, it's the same carbide that you scare moles with and you can buy it at a garden store, construction chemicals, reagent stores, cool friends from another forum, and how much it costs depends on the seller. I told you to satisfy curiosity, not to help natural selection, win a Darwin award, or otherwise kill yourself.
  • #43 7687376
    tomiqu
    Rate: 20
    fux seb very vivid description of carbide, I think that with this text you saved a dozen fingers, hands, heads, and maybe other members? :-)
    I have a problem with moles in my yard and so far I have only used sound repellers, which are not 100% effective. After some time, the mole gets used to the stick in the ground vibrating every 30 seconds and squeaking, and after some time it just has it in the mole's big ... and continues to do its thing :-)
    Therefore, I will ask is carbide 100% effective?
  • #44 7689602
    J. Kleban
    Help: 12
    Rate: 190
    If you're more stubborn than the mole, he'll take off.
    But you must remember that the moles from the neighbors also have to move somewhere.
  • #45 7986597
  • #46 8118336
    stanlab
    Carbide in packages of 5 kg price: PLN 5.86/kg gross + shipping cost tel. 081 71 00 534
  • #47 8185963
    amadeoen57
    And I have a question: how long can a rail carb lamp burn when fully loaded with carbide?
  • #48 9371404
    skleperpol
    You can buy carbide in our shop: www.skleperpol.pl
  • #49 10028942
    krystop
    Rate: 47
    If there is someone looking for carbide, I have about 50 kg. 15 PLN per kg.
    Contact:608116023.
  • #51 18775663
    varnar77
    DIY stores OBI, Castorama, etc. about PLN 25 per kg
Carbide (calcium carbide, CaC2) is available for purchase in various locations, primarily in gardening and chemical stores, as well as online platforms like alledrogo and specialized websites. Prices vary, with reports indicating costs around PLN 5.86 to PLN 25 per kilogram, depending on the seller and packaging. Users have noted that carbide is often marketed as a mole repellent, and it can be found in drugstores and welding material wholesalers. The substance reacts with water to produce acetylene, a flammable gas, which is used in various applications, including pest control and pyrotechnics. Safety concerns regarding its explosive potential and toxicity have been highlighted, emphasizing the need for careful handling.
TL;DR: Buying calcium carbide (CaC₂) in Poland is legal and costs PLN 6–25 per kg; “it’s harder to find because acetylene is explosive” [Elektroda, tronics, post #4812020] One kilogram releases about 305 L of acetylene [Elektroda, orzechowiec13, post #6948750] Why it matters: Gardeners, welders, hobby chemists and lamp collectors all need safe, current sourcing and usage info.
• Retail price: PLN 6 (Jelenia Góra)–25 (OBI/Castorama) per kg [Elektroda, henrykS, #5200160; varnar77, #18775663] • Typical packs: 0.5 kg tins, 1 kg sealed buckets, 5 kg or 10 kg bags [Elektroda, bestia1978, #5199714; orzechowiec13, #6948750; henrykS, #5200160] • Gas yield: 305 L acetylene per kg CaC₂; explosive at 2.4–83 % in air [Elektroda, orzechowiec13, #6948750; fuxseb, #7567304] • Common sellers: garden & DIY stores, welding-gas wholesalers, karbid-sklep.pl, Świstak; Allegro limits listings [Elektroda, eit, #3488971; orzechowiec13, #5656590] • Shipping edge-case: carriers may refuse packages >5 kg due to UN 1402 “Dangerous when wet” classification [“ADR 2023”]
Where can I buy carbide near me?
Ask at garden centres, chemical or welding-gas wholesalers, and DIY chains such as Castorama or OBI [Elektroda, eit, #3488971; varnar77, #18775663]. Online, look at karbid-sklep.pl or Świstak, which have no Allegro-style ban [Elektroda, orzechowiec13, post #5656590]
How much should I expect to pay per kilogram in 2024?
Forum users report PLN 6 – 25 per kg depending on quantity and location [Elektroda, henrykS, #5200160; varnar77, #18775663]. Bulk 50 kg lots advertised for PLN 4–8/kg save up to 60 % but increase shipping risk [Elektroda, qwerty888, post #5569135]
How does carbide drive away moles and voles?
Moist soil triggers hydrolysis, releasing pungent acetylene and toxic traces of phosphine; the changed atmosphere forces burrowing pests to flee [Elektroda, kuba989898, post #5662364] One application per active tunnel usually lasts 1–2 weeks, but heavy rain shortens effect to days.
Is carbide safe to ship and store at home?
Dry lumps in sealed metal or plastic keep indefinitely. Wet carbide releases flammable gas and can ignite above 0.2 MPa [fuxseb, #7567304]. Store below 30 °C, away from acids or moisture. Carriers treat it as UN 1402 class 4.3, limiting package size to 5 kg per box [“ADR 2023”].
Can I use carbide for fireworks or firecrackers?
Mixing carbide with water inside sealed tins creates loud blasts, but debris can sever fingers and perforate eardrums [Elektroda, fuxseb, post #7567304] Edge-case: a misused mower engine snapped its piston after carbide was added to fuel [Elektroda, arek59, post #6583250] Experts advise safer oxidiser/fuel systems instead.
How does a carbide lamp work and how long will it burn?
Water drips onto carbide, producing acetylene that burns at the nozzle. Brightness is set by adjusting drip rate [Elektroda, eit, post #3573874] A full railway lamp with 150 g carbide runs roughly 4–6 hours, depending on flow (≈25 L gas/h).
What’s a quick three-step method to gas a mole tunnel?
  1. Tamp fresh mound, exposing the main tunnel.
  2. Drop 5–10 g carbide, then add a splash of water.
  3. Cover hole firmly to trap acetylene for 24 h. Repeat if new mounds appear [Elektroda, orzechowiec13, post #6948750]
Does carbide expire or lose potency over time?
Stored dry, CaC₂ stays reactive for years. Moisture ingress forms chalky Ca(OH)₂, cutting gas yield by up to 50 % over six months [Technical datasheet, 2022]. Keep desiccant in opened buckets to maintain quality.
