How to calculate the area of a triangle in the xy coordinate system?
lipek86 37381 13
How do I calculate the area of a triangle from the coordinates of its three vertices in the xy plane?
Calculate the triangle’s area either with a base-height method or with a coordinate determinant/cross-product shortcut. First compute side lengths with the distance formula √((x1−x2)^2 + (y1−y2)^2); for the example A(5,3) and B(10,4), one reply gets |AB| = √26 [#323119][#323122] Then find the height as the distance from point C to the line through AB; one post does this and reports h = 5√2, giving an area of about 18 square units [#323134] Another reply says the area can also be found directly from the coordinates using a determinant/cross-product form, roughly (x1*y2 − x2*y1)/2, after choosing two side vectors from a vertex [#323128][#323305]
  • #1 323068
    lipek86
    Help: 36
    Rate: 26
    Some of you know this pattern. I used to have it in junior high school, but I can't find it, and I need it very much
    I have the coordinates of the vertices:
    A = (5.3)
    B = (10.4)
    C = (2.8)
    I am asking for this pattern
    thanks
  • #2 323088
    Tdv
    Help: 150
    Rate: 53
    Using the method of the engineer Nachamow, the field for Ci should be 15.5, but the pattern I took and a long time ago ...
  • #3 323099
  • #4 323102
    elektryk
    Help: 439
    Rate: 241
    Heron's formula:
    P = [p * (pa) * (pb) * (pc)] ^ (1/2) (to the 1/2 power it is actually a square root but I can't write it) p is half the circumference p = (a + b + c) / 2
    Knowing the coordinates of the vertices, I think you will be able to calculate the lengths of the sides (a, b, c) ;)
  • #5 323107
  • #6 323114
    lipek86
    Help: 36
    Rate: 26
    elektryk wrote:
    Heron's formula:
    yes, I know heron's pattern only I know how to count the lengths of the sides on the basis of coordinates. Enlighten me because somehow I don't have the strength to think. :? :( :cry:
    is there any pattern for that ???
    because as I now rozrysowłam it, I thought that it could be done with your Pythagoras.
  • #7 323119
    elektryk
    Help: 439
    Rate: 241
    the length of the segment is the root of the sum of the squares of the coordinate difference (I hope I was right), it looks something like this v [(x1-x2) ^ 2 + (y1-y2) ^ 2]
  • #8 323122
    Leap
    if two coordinates then
    root [(y1-y2) ^ 2 + (x1-x2) ^ 2]
    e.g. for A (5,3) and B (10,4)
    y1 = 5, x1 = 3
    y2 = 10, x2 = 4
    we substitute and we get the square root of 26
    that is | AB | = 5, piece ;)
  • #9 323126
    lipek86
    Help: 36
    Rate: 26
    y1 = 5, x1 = 3
    y2 = 10, x2 = 4
    we substitute and we get square root of 26
    That's right. I did it on tw. Pythagoras (I drew a layout xy) and the sides come out
    element 26
    square root 80
    square root 34
    then I think I can do it :)
  • #10 323128
    Leap
    and so, just like that, the area is counted with the help of determinants
    you do a 2 by 3 matrix and put the coordinates there and count ;)
  • #11 323134
    Gorgoroth
    Help: 28
    Rate: 63
    The area of the triangle is generally 0.5 * a * h. Let's assume that "a" will be episode | AB | so you count the length of the section about the ends in points (5,3) and (10,4)
    AB= sqr (x2-x1)^2 + (y2-y1)^2
    The length | AB | comes out = sqr26
    now you count the height "h" which is the distance of point C from the straight line passing through points A and B. So first you calculate the equation of the line passing through A and B
    y-y1 = (y2-y1) / (x2-x1)  * (x-x1)
    So we have an equation of a simple figure
    y = x - 20
    Now you find the distance of point C (2,8) from this line
    h = Ax0 + By0 + C / sqr (A^2 + B^2)
    Above you have the formula for the distance of the point C = (x0; y0) from the line Ax + By + C = 0.
    From this formula the distance of this point is 5 sqr 2.
    So you have all the data:
    a = sqr26
    h = 5sqr2
    So the area is ~ 18 square units
    And that's all :D
  • #12 323135
    elektryk
    Help: 439
    Rate: 241
    Leap wrote:
    and just like that, this area is counted by determinants
    I wonder how the determinant of a non-square matrix counts.
  • #13 323155
    Owsik
    Help: 12
    Rate: 30
    It is also possible to calculate from the formula given in the appendix by substituting the coordinates of the points ;)
    • How to calculate the area of a triangle in the xy coordinate system? Pole_Trojkata.gif (1.11 KB) You must be logged in to download this attachment.
  • #14 323305
    candle
    Monitors specialist
    Help: 38
    Rate: 18
    Siwy %% wrote:
    I don't remember either, because I went to gymnasium right after the war. But this is a product (I think an scalar) of two vectors defined by the sides of the triangle and a half, something like (X1 * Y2 + X2 * Y1) / 2 if that reminds you of something, (X1, Y1) is a vector - the side of the triangle. :idea:
    almost
    (x1 * y2-x2 * y1) / 2 ...
    I consider the subject as exhausted .. heron's formula is for people with too much time
    candle
The discussion revolves around calculating the area of a triangle given its vertices in the xy coordinate system. The main question seeks a formula for this calculation, specifically using the coordinates A = (5,3), B = (10,4), and C = (2,8). Various methods are proposed, including Heron's formula, which requires calculating the lengths of the triangle's sides, and the use of determinants for area calculation. The length of the sides can be determined using the distance formula derived from the Pythagorean theorem. The area can also be computed using the formula 0.5 * base * height, where the base is the length of one side and the height is the perpendicular distance from the opposite vertex to that side. The final area calculation yields approximately 18 square units.
