[Solved] Identifying Cable Cross-Section: Visual Inspection Techniques
slawo85 30710 8
  • #1 4256247
    slawo85
    Rate: 8
    Hello everyone, I have the following question. How to know the cross-section of the cable by looking at it?
  • #2 4256272
    darlon
    Help: 11
    Rate: 19
    you can try to strip the cable gently and check it with a micrometer if you have it, although I recognize cables ranging from 0.5mm to a few mm if they are not marked by eye. the method with a micrometer will not give 100% certainty because it can always happen that you will slightly bend the cable, but the margin of error will be rather small, let`s say that if the cable is 1 mm and comes out 0.8 mm, then the matter is obvious
  • #3 4256444
    adams987
    Help: 288
    Rate: 138
    It is easy to notice and measure differences with larger cross-sections, e.g.:
    4mm² is 2.256mm diameter,
    2.5mm² is 1.78mm
    1.5 mm² is 1.38 mm
    1 mm² is 1.12 mm
    0.75mm² is 0.97mm
    0.5 mm² is 0.80 mm
    As you can see, with a cross-section below 1 mm², it is difficult to measure the diameter and be sure because if the measurement result is 0.85 mm, you are not sure what the cross-section is. But with larger ones, you can easily measure the diameters and you won`t be wrong.
  • #4 4256873
    slawo85
    Rate: 8
    I am rather interested in wires with diameters above 1.5 mm2. Let`s assume I measure the diameter of the cable (with a caliper, we don`t measure it so precisely at work that we need to use a micrometer) and it is 2.2mm2, then you can guess that it is a 2.5mm2 cable. And for larger diameters, e.g. 8, 10, 35, 50, 70mm2, etc. Is there any formula for this? Is it intuitive?
  • #5 4256922
    k4be
    Help: 102
    Rate: 333
    Diameter in square meters? 8-O You can use a caliper to measure the regular diameter (in mm) and convert it to cross-sectional area using formulas known from primary school.
  • #6 4256936
    adams987
    Help: 288
    Rate: 138
    The cross-section of the wire is in mm² and its formula is pi • r². You measure the diameter of the wire, which is in mm, not the cross-section. If the diameter you measure is, for example, 2.2 mm, then you calculate the cross-section:
    r=1/2 d, i.e. r=1/2 x 2.2 mm= 1.1 mm. Cross-section = 3.14
    In the previous post I wrote what diameter corresponds to the cross-section of 4, 2.5, 1.5, 1, 0.75 and 0.5mm²
  • #7 4257370
    slawo85
    Rate: 8
    Thanks for the answer, and is it the same in the case of thicker cables, e.g. a cable diameter of 70 mm, would it mean that the cross-section would be 3845.5 mm2? There is no such thing??!!
  • #8 4257492
    adams987
    Help: 288
    Rate: 138
    I don`t know, but I haven`t come across a 7cm cable (it`s a power cable). The formula for the area of a circle (i.e. cross-section) is P=pi x r² and you will not change it. You did the calculation correctly, so maybe the diameter is not 70 mm, but either less or more.
  • #9 4257863
    slawo85
    Rate: 8
    OK, I understand everything now. Thanks for the help
The discussion focuses on techniques for identifying the cross-section of electrical cables through visual inspection and measurement. Users suggest using tools like micrometers and calipers to measure the diameter of the cable, which can then be converted to cross-sectional area using the formula for the area of a circle (A = πr²). Specific diameters corresponding to common cross-sectional areas (e.g., 0.5 mm² to 4 mm²) are provided, highlighting that larger diameters are easier to measure accurately. The conversation also touches on the challenges of measuring smaller cross-sections and the potential for error in measurements. A user inquires about the applicability of these methods for thicker cables, and the group confirms that the same principles apply, although they express skepticism about the existence of extremely large diameters like 70 mm.
