Calculate Irregular Shape Area in AutoCad 2002: Efficient Methods & Techniques (max 90 chars)
asterix27 57363 3
  • #1 907976
    asterix27
    Level 19  
    Rate: 36
    I would like to know if AutoCad 2002 can calculate the area of some geometric figure with irregular shapes. I have to calculate the surface area of a very complicated plane figure. Manually on paper, I would have to divide it into squares, triangles, rectangles, etc., calculate the area of each of them separately, and then add them up. I'd rather put it into AutoCad. Question: is it possible to calculate such an area using this program, and how is it done?
    Thanks for your reply. Regards.
  • #2 909635
    asterix27
    Level 19  
    Rate: 36
    can no one answer this question???
  • #3 909825
    000andrzej
    Level 37  
    Help: 302
    Rate: 238
    You have a "Query" bar in the toolbar (if you don't have it, turn it on). There you can calculate the area, and even the volume of solids, mass, etc. ... combine. :wink:
    you can also enter the command "field" and select all points, or mark the figure as an object and give the object's area. Take a look at the help. Of course, as you have drawn to scale.
  • #4 910073
    asterix27
    Level 19  
    Rate: 36
    Thanks for the answer :) I didn't actually have this active bar :) I even have a book, but there I searched under the term "area and not area :) Now it's child's play :) thanks
