AEG Favorit 40-860 Dishwasher: Deactivating Anti-Flooding Lock (Error i30)
harryd 66941 18
How can I clear the i30 anti-flood lock on an AEG dishwasher and stop it from coming back?
You do not clear i30 with a button combination; you must remove the water from the flood tray at the bottom of the dishwasher and fix the cause of the leak or blockage, otherwise the error returns [#3546161][#3546476][#3547286] Tilt the dishwasher backwards or remove the lower/front panel so the water under the machine can drain out, then dry the tray completely [#3546476][#17099021] Check for leaks in the hose from the solenoid valve to the water jacket, the drain hose under the dishwasher, and the pump/overflow area, because these were reported causes of i30 [#3546322][#3550825][#10131355] One case was caused by a clogged regenerator/softener area; cleaning it or flushing it with descaler helped, and another was caused by debris blocking the overflow path [#6121054][#17099021] Disconnect the dishwasher from power before opening the base, because there are 230V wires inside [#17099021]
  • #1 3546141
    harryd
    Rate: 32
    After turning on the dishwasher, the error "i30" is displayed, which means that the anti-flooding lock has been activated. Does anyone know how to turn off?
    Thanks a lot
  • #2 3546161
  • #3 3546277
    harryd
    Rate: 32
    everything is cleared but still crashes the error is displayed after starting, maybe it is some combination of buttons that clears the error. ?
  • #4 3546322
    andrzej-jur
    Help: 17
    Rate: 68
    you canceled the effect and the cause repeats? Locate the cause
    water leakage Check the rubber hose coming off the solenoid valve!
    greetings Andrzej
  • #5 3546348
    harryd
    Rate: 32
    The hose from the solenoid valve is visually in good condition, the dishwasher is maybe less than a year old and it has not been pulverized, what can you find in it? (what type of damage)
  • #6 3546372
  • #7 3546392
    harryd
    Rate: 32
    I deleted with the reset buttons, unfortunately the program will delete it, but the error will crash after a while
  • #8 3546413
  • #9 3546439
    harryd
    Rate: 32
    There was, I removed it, the water inside the dishwasher pumped out and it was dry now
  • #10 3546476
  • #11 3546582
    harryd
    Rate: 32
    Yes, it flew out and the error was removed, I threw him a 30-minute program, let them grind it there and then unfold it and see what is. what mate Bleble are you betting that it could be the reason?
    Added after 26 [minutes]:
    hmm, I came up with one more thing that may be the reason, it may be that such an innocent creature as a woman in the house, pressed some program from which she could not withdraw, the dishwasher sucked in water and she sucked her nerves - to push her finger on a large button (back off). the water inside was not poured out and after a few days it was discharged? it can be like that? because the woman won't confess! such a fate :D
    Mod. ROBSON33
    Regulations 3.1.13. (10.9, 15)
    It is forbidden to publish entries that violate the spelling rules of the Polish language, careless and incomprehensible.
    Please correct the post without deleting the above post.
  • #12 3547286
  • #13 3550825
    andrzej-jur
    Help: 17
    Rate: 68
    However, the cause must be in the leaky hose extending from
    solenoid valve to the jacket-water tank. Or they are contaminated
    water inlet strainers There is insufficient water pressure i
    water flows down to the sensor through the venting channel
    Aqva-stop.
    greetings Andrzej
  • #14 6120768
    kalep
    Rate: 43
    I went all the way described above.
    Water drips during filling from the place marked in the photo
    What can you do about it?
    Visually, everything is fine.
    please advice.
  • #15 6121054
    cezet
    Help: 719
    Rate: 1407
    You have a clogged regenerator - a container with a brown water softener like that.
    If you manage to do this, put e.g. a descaler into the hole marked with an arrow (in the photo) and wait for it to get into the brown container. It should help.
  • #16 6122831
    kalep
    Rate: 43
    I have a slightly different model of dishwasher with me, this opening leads to the washing chamber, and this brown wire to the salt container. There is salt in it and I think the cable is open.
    I noticed that when pouring water, the stream is uneven, could it be something with a water supply valve ???
  • #17 6134241
    kalep
    Rate: 43
    I solved the problem by sealing this hole with tape :)
    I just don't know what the further consequences may be ?? Maybe someone knows ??
  • #18 10131355
    szudi13
    The same problem, code 30 appeared, Tilting the dishwasher helped for 3 minutes then again code 30 appeared. The problem was that the drain hose under the dishwasher was sliding.
    Mod. ROBSON33
  • Clogged overflow and tray caused i30 error
    #19 17099021
    Wgrzeg1980
    Gentlemen, Colleagues!
    I would like to share my AEG FAVORIT 7800vi1p repair method.
    Error i30 - water in the flood control system - the user manual says - turn off the water supply and call a service technician. I live in a place where service technicians are available in 3 weeks.
    I searched the net, I recommend YouTube videos - there are several of them, especially in German.
    My solution was to cover the bottom of the dishwasher with baking soda and pour boiling vinegar over it all. I left it for 20-30 minutes. After this time, the machine "spat out" the orange seed from the hole which I am pointing to with a screwdriver. A swollen one that was clearly blocking one of the tubes. While rinsing with soda and vinegar, various "farfocle" flowed out in the surf. A pump works in this opening, which is responsible for cleaning the dishwasher from water.
    In one of the German videos, the foreman advised to remove the front panel at the bottom of the dishwasher (I have 4 self-tapping screws). After removing this mask, I found the aforementioned tray full of water that needed to be cleaned. I used kitchen paper for this. Disconnect the dishwasher from the power supply because it is full of 230V wires !!!
    Not knowing the complete structure of the dishwasher, I suspect that the overflow was blocked by this stone (a small hole in the gray housing with a ball valve). Instead of being evacuated through the (clogged) drain, the water returned to the chamber in the photo through this overflow (at the moment of pressing it with a toothpick).
    Illustrative photo AEG Favorit 40-860 Dishwasher: Deactivating Anti-Flooding Lock (Error i30)
    I started a quick program - there was no more water downstairs. I don't think the leak is anywhere.
    Final advice - teach your beautiful half that your nails will not fall off from cleaning filters regularly and from rinsing dirty, dried-up plates from dried greasy food residues. If he resists, convert the cost of the foreman's visit to the number of sessions at the manicist's :) (My love does not have such problems, but it disgusts these types of nooks and crannies) and in this case the machine fell on the cheese, tomato sauce and fat that I found when the i30 error appeared.
The discussion revolves around the AEG Favorit 40-860 dishwasher displaying the "i30" error, indicating that the anti-flooding lock has been activated. Users suggest various troubleshooting steps, including checking for water accumulation inside and underneath the dishwasher, inspecting hoses for leaks, and resetting the program. Some users recommend tilting the dishwasher to drain any trapped water and suggest that the issue may stem from a clogged water inlet or a malfunctioning solenoid valve. One user shared a DIY solution involving baking soda and vinegar to clear blockages. Overall, the consensus is that the problem is likely related to water leakage or blockage in the drainage system.
