Calculating Wire Cross-Section from Diameter, Length, and Resistance Formula
lucasek 77947 9
  • #1 3851463
    lucasek
    Rate: 9
    How can I calculate the cross-section of a conductor based on diameter, length and resistance ??? Is there a formula I can use to calculate something like this?
  • #2 3851536
    WojtasJD
    Help: 2911
    Rate: 1576
    As for the cross-sectional area, it can be calculated knowing only the diameters: (? * d ^ 2) / 4
  • #3 3851561
    elek555
    Level 37  
    Help: 310
    Rate: 250
    Look at the patterns from the primary school for the area of the figures you have visible as the cross-section of the wire. Use the measuring cup and count S.
    For a circular cross-section S = 0.25?d?, ??3.14 d-wire diameter
    And connect the resistance with the formulas R = ?l: S, ?-resistivity from the tables l-length
  • #4 3851601
    lucasek
    Rate: 9
    Well, so much that substituting these patterns for the result has nothing to do with the one given in the tables.
    Added after 7 [minutes]:
    for example, with a steel wire diameter of 1.43mm and a resistance of 4287.3 Ohm, a length of 1m ... the resistive result is in the order of 14042.66 ... while the table shows that it should be 0.027 * 10 ^ (- 6) !!!
    Added after 16 [seconds]:
    What am I doing wrong ????
  • #5 3851828
    BolzZ
    Help: 56
    Rate: 67
    hmm, but you asked how to count the wire cross-section and you count the conductor resistivity :D
  • #6 3851948
    WojtasJD
    Help: 2911
    Rate: 1576
    d = 1.43mm
    R = 4287.3 ?
    l = 1m
    ? = R * S / l = 4287.3? * (1/4 * ? * (1.43mm ^ 2)) / 1m = ~ 6.886 * 10 ^ (- 3) ?m
    The resistance of this cable is quite high, besides, it is not known what steel, what temperature.
  • #7 3852216
    Quarz
    Help: 1646
    Rate: 628
    WojtasJD wrote:
    d = 1.43mm
    R = 4287.3 ?
    l = 1m
    Spore resistance of this cable, besides, it is not known what steel, what temperature.
    if it's not resistance, only resistivity , i.e. the material constant, and this is the fundamental difference.
    After all, you have calculated ? = 4,287.3 o 3.14159 o (1.43 / 2000) ^ 2/1 = 6.885658E-0003 ? o m
  • #8 3852237
    WojtasJD
    Help: 2911
    Rate: 1576
    :arrow: Quarz
    I know what I have calculated :wink: and I wrote it well - I wrote (or actually commented) about _resistance_ R = 4287.3? given earlier by col. lucasek (because a 1m steel wire with a diameter of 1.43mm with over 4k? is a bit much ...)
  • #9 3852264
    Quarz
    Help: 1646
    Rate: 628
    WojtasJD wrote:
    :arrow: Quarz
    so for the future AND AND means a B B mean... :D
  • #10 3852443
    elek555
    Level 37  
    Help: 310
    Rate: 250
    Some miracles happened to my colleagues higher because steel is harder to conduct, but this is not a reason for it to become a high resistance wire. Following Wikipedia and assuming that all iron has ??10 ^ -7?m, with a cross-section of about 1.6mm? and a length of 1m, the resistance comes out to about 1/16 ?. Of course, you can count it more precisely, but I don't want to.
✨ The discussion centers on calculating the cross-sectional area of a conductor using its diameter, length, and resistance. The formula for the circular cross-section is provided as S = (π * d^2) / 4, where S is the cross-sectional area and d is the diameter. The relationship between resistance (R), resistivity (ρ), length (l), and cross-sectional area (S) is also highlighted with the formula R = ρ * (l / S). A user raises concerns about discrepancies between calculated resistivity values and standard tables, particularly for a steel wire with a diameter of 1.43mm and a resistance of 4287.3 Ohm. The discussion emphasizes the importance of understanding the difference between resistance and resistivity, as well as the material properties affecting conductivity.
