Reprogramming Key After Battery Replacement in 2003 Toyota Corolla E12
Panjarekp 52290 16
How do I reprogram the remote key on a 2003 Toyota Corolla E12 after replacing the battery?
Reprogram the remote by doing the door/ignition sequence quickly: open the driver’s door, perform the close/open and insert/remove key steps, then turn the ignition to ON once and remove it, confirm with the lock, press the remote buttons in the required sequence, turn the ignition on for 10 seconds, remove it, and press UNLOCK twice [#8237573] This answer in the thread refers to remote-control coding, not the immobilizer/transponder [#15987107] If the car still will not start and the security light flashes, the transponder is a separate issue; it needs a clean/new ID4D transponder and cannot be recoded from another car by yourself [#15988287][#15987813]
  • #1 3969952
    Panjarekp
    Rate: 146
    I bought a Toyota Corolla (2003) with 2 keys. In one of them the battery died, after replacing the battery the key stopped working. It probably needs to be programmed, unfortunately I only have the user manual in Dutch... On the forum I found a solution to this problem in Avensis (unfortunately it didn`t work in my car) :cry:
    http://preview.tinyurl.com/ywpafv
    I think the answer is in the user manual... but you need to have it in Polish.
  • #2 3972674
    zibi70
    Help: 12
    Rate: 50
    Write to be sure what engine you have there
  • #3 3972710
    Panjarekp
    Rate: 146
    D4D 66kW engine. The key says Valeo 08/433.92 MHz, CE 0165.
  • #4 3974568
    Panjarekp
    Rate: 146
    The problem was solved thanks to a colleague from the Toyota Forum - Bigelektron
    TOYOTA SPEC. :D
  • #5 4263662
    Panjarekp
    Rate: 146
    I have a problem with the spare key again, which I haven`t used for two months. Today I tried to start the car with it and it failed. The central locking worked, but after turning it into the ignition, the red Security light continued to flash. And the engine couldn`t be started. What to do?
    I`m counting on the experts from the Elektroda forum.
  • #6 8237001
    bartlomiej.z
    Rate: 14
    Hello, I would like to know how the problem with key coding after changing the battery was solved? (I have a Toyota Corolle hatchback from 2003) [please reply by e-mail: bartlomiej.z(_at_)gmail.com]
  • #7 8237573
    Panjarekp
    Rate: 146
    Driver`s door open
    Put in the howler
    put in the howler
    close open
    close open
    insert and remove once
    close open
    close open
    put on
    close
    turn the ignition switch to ignition once and remove it, confirm with the lock, press the remote control buttons 2 at a time and after a second 1 of them.
    turn on the ignition for 10 seconds
    remove and press UNLOCK twice
    You have to do it as quickly as possible... have fun
  • #8 8248753
    bartlomiej.z
    Rate: 14
    I understand that you insert and remove the key from the ignition and close and open the driver`s door?
    thanks for the answer
  • #9 8248775
    Panjarekp
    Rate: 146
    Yes, it`s about the key.
  • #10 15987037
    krzyyysztof
    Help: 8
    Rate: 21
    Is it possible to program an immo transponder from another key using the methods mentioned above?
    Regards
  • #11 15987107
    piotrekwoj1
    Help: 947
    Rate: 3433
    This is remote control coding, not immo, unless I`m wrong.
  • #12 15987305
    krzyyysztof
    Help: 8
    Rate: 21
    piotrekwoj1 that`s what it seemed to me at first, but considering what he wrote Panjarekp this would also point to Immobilizer.
    Hence my question: will another transponder be suitable or is it the ASO?
    Best regards
  • #13 15987589
    piotrekwoj1
    Help: 947
    Rate: 3433
    This is above, this is programming the remote control on immo, there is another way. What color are your keys?
  • #14 15987679
    krzyyysztof
    Help: 8
    Rate: 21
    Black with a built-in 2-button remote control.
    Due to the fact that it is a bit bent for fear of breaking, I made a regular one without a remote control, which, after replacing the transponder, obviously starts the car without any problems.
    Hence my question: if I get such a transponder, will I encode it myself or will I need an authorized service center (I would like to have two "armed" keys).
    Regards
  • #15 15987813
    piotrekwoj1
    Help: 947
    Rate: 3433
    Go to the place where they make keys and ask for the price, there is an ID4D there so they will easily copy it. I don`t think you can code from anything else.
  • #16 15988287
    milejow
    Help: 1563
    Rate: 5149
    krzyyysztof wrote:
    Hence my question: If I get such a transponder, will I encode it myself?
    You won`t be able to code it yourself and there`s no need for an ASO, just an electronics technician with the knowledge and equipment (where they make key copies, they`ll know what`s going on).
    One last note: the transponder must be clean/new, you cannot re-code it to another car.
    Działalność własna
    Mętów 99, Lublin, 20-388
  • #17 15988764
    krzyyysztof
    Help: 8
    Rate: 21
    piotrekwoj1 wrote:
    that`s where ID4D sits
    milejow wrote:
    no ASO needed,
    Thanks for the info. I`ll ask around in my area.
    Regards
The discussion revolves around reprogramming a key for a 2003 Toyota Corolla after a battery replacement. The original poster encountered issues with one of the keys not functioning post-battery change, suspecting it required reprogramming. Various users contributed solutions, including a detailed step-by-step method for reprogramming the remote control functionality. The conversation also touched on the distinction between remote control coding and immobilizer programming, with suggestions for obtaining a new transponder if needed. Users emphasized the importance of using a clean/new transponder and recommended consulting an electronics technician for key programming rather than an authorized service center.
