Re-Code Toyota Corolla Verso Keys 1 & 2: Battery Replacement, Central Lock, Start/Stop System
jablonski1 7116 6
  • #1 16414416
    jablonski1
    Please help me re-code the key. Today, both 1 and 2 keys have the batteries replaced, the red light is on and the car does not close and opens at the central lock.
    The car has a start / stop system.
  • Toyota key transmitter programming and mode selection procedure
    #3 16414442
    andrzej20001
    Help: 1578
    Rate: 6678
    Begin with:
    The driver’s door open and unlocked.
    Key out of the ignition.
    1. Insert and remove the key from the ignition switch 2 times within 5 seconds.
    NOTE:
    Steps 2 and 3 should be performed within 40 seconds.
    2. Close and open driver’s door TWICE.
    3. Insert the key into the ignition and remove it.
    NOTE:
    Steps 4 – 6 should be performed within 40 seconds.
    4. Close and open the driver’s door twice.
    5. Insert the key into the ignition.
    6. Close the door.
    NOTE:
    Steps 5 and 6 should be reversed for the following models ONLY (close door first,
    then insert key into ignition):
    2000 – 2005 Celica
    2001 – 2003 Prius
    2001 – 2005 ECHO
    2001 – 2005 RAV4
    2003 – 2004 Avalon
    7. Turn the ignition switch from “Lock” to “On” and back to “Lock” at about 1 second
    intervals to select the desired mode:
    1 time for ADD mode.
    2 times for REWRITE mode.
    3 times for CONFIRMATION mode.
    5 times for PROHIBITION mode.
    8. Remove the key from the ignition.
    9. To confirm your mode selection, the power locks will now cycle “lock” to “unlock” a
    number of times corresponding to your key cycles in step 7.
    NOTE: If Confirmation or Prohibition modes have been selected, opening the door will
    complete the procedure.
    10. For Add or Rewrite modes do the following within 40 seconds of Door
    Lock confirmation:
    A. Press both transmitter Lock and Unlock buttons simultaneously between 1 and
    1.5 seconds and release.
    B. Within 3 seconds of step A, press the transmitter Lock button for more than 1
    second and release.
    NOTE: If the transmitter has been successfully programmed, the power locks will
    cycle “lock” to “unlock” once at this time. If there are problems with the transmitter or the procedure up to this point, the locks will cycle twice. If this occurs, verify that you have received the correct transmitter, and then repeat the above procedure.
    C. If multiple remotes are to be reprogrammed, repeat steps A and B.
    11. Open the driver’s door to conclude programming mode.
  • AliExpress 433 MHz key fails to pair at step 6
    #4 21740765
    Kollorowy
    I am trying to program the ignition key according to the instructions below:
    Central locking remote control programming method (remote control-key used, from another car):
    Key removed from ignition.
    Driver's door open.
    1. Key - in/out, in/out.
    2. Door - close/open, close/open.
    3. Key - in/out.
    4. Door - close/open, close/open, lock.
    5. Key - insert, turn ignition on/off, remove key - central locking system locks and opens by itself.
    6. Press lock and unlock simultaneously on the remote control for 1 s, then one of the buttons before 3 s.
    7. Open/close the driver's door. End.
    By key I mean of course the "card" - the remote control to start the car.
    All goes well up to point 5. I perform point 6 and 7, but nothing happens, the key does not want to save the settings. I bought the key on AliExpress (433 MHz), because the original is MDL B21TA
    https://pl.aliexpress.com/item/10050079587345...in.17.19411c24dXKi9D&gatewayAdapt=glo2pol
  • #5 21740822
    andrzej20001
    Help: 1578
    Rate: 6678
    The card must be added to the car. What you are attempting to do is control the lock.
  • #6 21741833
    Kollorowy
    That's what I'm trying to do - program the remote control for the central locking and unfortunately the final stage doesn't work. I don't know what I'm doing wrong...
  • #7 21741909
    andrzej20001
    Help: 1578
    Rate: 6678
    You need an interface and the right software.
Discussion about re-coding Toyota Corolla Verso keys after battery replacement in both key fobs, where the red indicator stays on and the central locking no longer locks or unlocks the car. The topic includes a Toyota key/remote programming procedure for adding or rewriting a remote, but the described sequence fails at the final save step. It is clarified that the key/card must be added to the vehicle rather than only controlling the lock, and that programming requires an interface and the correct software. The car is equipped with a start/stop system, and an aftermarket 433 MHz replacement key/card was purchased, but it does not complete pairing.
