How to install a socket – box set too deep behind bathroom tiles?
vojeq 17175 5
  • #1 4093247
    vojeq
    Rate: 10
    As in the topic. There is a problem in the bathroom that the socket box is set too deep by the tiles and when screwing the socket, the claws do not reach the plastic box. I don't know how to deal with this. Maybe you know how to deal with it?
    Thank you for your answers :D
  • #2 4093371
    shadow125
    Help: 29
    Rate: 26
    I had a similar problem. I made slightly longer legs from an old "herring" from a computer case. I bought a socket in which the cover is placed on the internal part.
  • #3 4094486
    puszak
    Help: 92
    Rate: 114
    I would use longer screws and sleeves of appropriate length
  • #4 4094568
    Mariusz Ch.
    Help: 866
    Rate: 461
    Please, no makeshifts. :D Solving the problem costs 60 cents. Look here:
    http://simet.jelonka.com/?menu=79&submenu=9f
    In the "Can accessories / spacer rings and covers" catalog
    you have everything.
    Regards
  • #5 4094699
    vojeq
    Rate: 10
    I see :D
    I didn't know such a thing even existed. Cool thing. I'll try to ask about something like this in the store.
    Thanks a lot.
  • #6 16280499
    Oks21
    It is probably worth leaving one more link here, because sometimes a specialist will place the tins and glaze in such a way that it is impossible to use an extension.
    http://poradnikfachowca.pl/2017/02/15/ Obaj-gleboko-odzone-puszki-radzimy-jak-rozwiazac-problem/
