Laying Cables in Reinforced Concrete Walls: Cable Routing, Mounting Boxes & Socket Installation
monterplus 42728 10
How can I route cables and install sockets in reinforced concrete walls without having to chase 20 deep holes for box mounts?
Avoid chasing the reinforced concrete if you can; use surface cable routing in skirting boards, cable trays or slats, and place the sockets low, about 10 cm from the floor, with the wiring hidden in the skirting channels [#4520140][#4520263] If you want the devices themselves to look more like flush-mounted ones, you can use under-plaster sockets and switches while still keeping the cable run in surface-mounted trunking [#4520140] One reply also suggests that if the wall plaster is thick enough, you may only need to cut grooves in the plaster layer, without disturbing the concrete, but in reinforced concrete there is often no other practical way than surface installation or a lot of drilling and chiseling [#4518664][#4518534] For lighting, ceiling outlets may still need to be chased, but junction/connector boxes can be used for the lighting connections [#4520263] Concrete box holes are possible with a concrete-rated crown or drilling-and-chiseling method, but they are slow, expensive, and hard work [#4518536][#4518664]
  • #1 4518338
    monterplus
    Rate: 17
    Let's assume that the electrical installation in a block made of large slabs - reinforced concrete walls (let's add that it is also made of aluminum) can be replaced, then what way of cable routing, mounting boxes, sockets can be used.
    The existing installation was carried out in the floor with the use of sockets and small surface-mounted boxes.
    It is not necessary to lay cables in the floor (laid parquet and laminate flooring).
    In the apartment you need to build new sockets, let's say 20 pcs. and I can't imagine forging 20 holes in reinforced concrete.
    If you have any ideas on this topic, please help.
    Moderated By skryn:
    I transferred from "Others".
  • #2 4518408
    obi997
    Help: 125
    Rate: 115
    I live in a block of concrete panels and my electrical installation is under the plaster in the walls. Electric sockets, light switches etc. are surface mounted. Last year, I did a little bit of redoing the installation, moving the contacts, replacing the switches. As for the location of the cable, it could be hidden under the plaster. Since I do not like surface-mounted sockets and switches, I decided to cut holes and insert the cans. When it was a brick partition wall, it was ok, but the stairs started at the concrete. I got a Bosch drill with a hammer and the ability to put on a hammer hammer, plus decent core drills. To make 8 holes for cans in reinforced concrete and I will say that it was not easy. But I talked to a few people and whoever dared to put the cans under the sockets had similar adventures. It is always worse to process than to build from scratch.
  • #3 4518498
    monterplus
    Rate: 17
    Yes, forging is the greatest macabre !!!!
    To make it as little as possible, I want to use deep fi60 cans, but I do not know if I can even use lace and a hammer to drill through the reinforcement !!!
  • #4 4518534
    WoŹnY
    Help: 76
    Rate: 149
    A decent lace and the reinforcement. Apart from that, there is nothing else but forging and that's it. There is no other way. As for the cables, if they do not fit under the plaster, and they must, unfortunately, it remains to shoe the old plaster under the cables as much as possible and put a new grinder, or a KG board. Then who taught you to do the renovation from the end, ie from the floor? Now make the walls and finally the ceiling, and after this order the walls and floors can be made anew.
  • #5 4518536
    Bogdanor
    Help: 78
    Rate: 32
    Yes, you can buy lace for drilling holes for cans.
    http://www.nokaut.pl/oferta/wiertlo-diamentowe-puszkowe-dbst-premium-srednica-68mm.html
    The drill must also be neat:
    http://www.muratorplus.pl/technika/elektronar...arzedzia_-sprzet/mloty-udarowe,25454_2821.htm
    If you want to run a new installation, you can think about skirting boards with the possibility of running cables, or about plastic trays.
  • #6 4518594
    monterplus
    Rate: 17
    It's not me who is planning the renovation, my friend is asking me for a favor to replace the installation. The case is that everything can be done but at the right price. The apartment has 4 rooms, bathroom and kitchen + new switchgear with differential.
    Let's assume that there will be about 20 sockets, 8 light points, a switchboard.
    As we can see on the link above, the fi60 crown is over PLN 200!
    The question is how much can it withstand in such a hard material, and how do chasers cope with reinforced concrete?
    Therefore, it is difficult to estimate the cost of such a "annoying" renovation.
    Perhaps one of the forum members will propose a preliminary settlement :)
  • #7 4518629
    andy355
    friend Bogdanor sent you a link with a hole saw for cans - good and expensive, but I would not recommend - look for something with the possibility of drilling with a stroke. I have such holesaw, unfortunately I do not remember where I bought it.
  • #8 4518664
    Bogdanor
    Help: 78
    Rate: 32
    I can't see the furrow chippers in zelbet, I can't (it will only "jump"). I used to work with a machine that had two blades mounted on one axis. They cut into the concrete, then all that was left was to "break" the middle ... But it's expensive equipment. The "amateur" methods are drilling holes with a thin drill and then forging them (but how much time ..). Besides, it depends on how solid this concrete is, what layer of plaster (maybe it is enough to make a groove in the plaster, without disturbing the concrete, for laying the cable). Also, think about skirting boards or cable trays, then just make them outlets for sockets / switches "plug" and it will be fine.
    ps Yes, there are many types of holesaws, but those suitable for concrete will always be expensive. (with or without impact)
  • #10 4520140
    Bogdanor
    Help: 78
    Rate: 32
    You are right, I also come back to my suggestion: installation of a surface (trays, slats - will not disturb the structure - no permits required), while the devices themselves (contacts, switches) are in "under-plaster". If, however, you insisted on "hiding" the cables in the plaster, I do not know .. maybe some professional will write something wiser.
  • #11 4520263
    zbyszek_
    Help: 56
    Rate: 109
    I can tell you that where you need to forge, you need to invest in equipment, which unfortunately costs less, in order to make less money. But I will probably save you forging if you use the skirting boards with conduits for cables and gn. Place the p / t at a height of approx. 10cm from the floor. In the door, also use strips to cover the wires. Unfortunately, for connectors, ceiling outlets should be forged. As lighting junction boxes, you can use connector boxes.
The discussion revolves around the challenges of installing electrical sockets and routing cables in reinforced concrete walls, particularly in apartments with existing installations. Users share experiences of drilling into concrete, emphasizing the difficulty of forging holes for mounting boxes and sockets. Recommendations include using deep mounting boxes (fi60) and specialized diamond hole saws for drilling. Alternatives such as surface-mounted skirting boards and cable trays are suggested to avoid extensive wall damage. The importance of investing in quality tools for effective installation is highlighted, along with considerations for the cost and complexity of the renovation process.
