How to Calculate Price of a 600x30x5cm Board if 1m3 Costs PLN 2000?
Tomaszek1989 71243 3
  • #1 4236833
    Tomaszek1989
    I mean the valuation of individual boards with a given price of 1m3. I count it like this:
    If I have a board
    length: 600cm
    width: 30cm
    thickness: 5cm
    the total volume of the board is 90,000 cm3
    1 m3 is 1,000,000 cm3
    that is, from the proportion it can be calculated that
    price for 1m3 * board volume in cm3 / 1,000,000 cm3
    assuming that a cubic meter of wood that I want to buy costs PLN 2,000, a board with the given dimensions will cost PLN 180.
    Or so?
  • #2 4236854
    jogaczew
    Help: 12
    Rate: 19
    but you will probably have to add the costs of trimming, you have to reckon with the fact that you have to adjust to the thickness of the board, not the thickness to you, so this may be a problem;]
  • #3 4236863
    any56
    Help: 656
    Rate: 840
    But the conversion is done well ...
  • #4 4236871
    jogaczew
    Help: 12
    Rate: 19
    if I went to the store, I would certainly prepare more cash, I would treat these calculations as approximate.
