Copper Cables: Alternative Ways to Remove Insulation Besides Burning (Non-flammable)
maciek.wroc 76420 11
How can I remove insulation from copper cables without burning them, for example by dissolving it or using another non-flammable method?
Yes—besides burning, cable insulation can be removed mechanically with a stripping machine: two metal shafts/rollers crush the insulation so it becomes brittle and can be pulled off, and one shaft needs an adjustable stroke [#4372909] For thicker copper wires this works well, but it is not very practical for thin car leads or electronic cables processed in large quantities [#5777073][#5780312] One user also suggested putting car cables into acid [#5777437] Several replies say there are no other really universal methods, so otherwise you are left with knives, pliers, or other laborious manual work [#4366169][#5779623]
  • #1 4366137
    maciek.wroc
    Help: 6
    I have a question that the copper cable only burns to get rid of these gums, and there is another way not to burn, but just dissolve something or something like that
  • #2 4366169
    majster_15
    Help: 64
    Rate: 51
    Well, on a larger scale, it is probably only burned in a fire, but then they are only suitable for scrap metal or for hanging laundry ;) The only thing left is a knife, pliers (vice) and some work ...
  • #3 4367437
    lechoo
    Help: 377
    Rate: 546
    Many buyers of non-ferrous metals do not want to accept burned copper because then there is a suspicion that it comes from a crime.
  • #4 4372909
  • #5 5748206
    przemyslw
    Help: 6
    Rate: 86
    What about a thin rope?
  • #6 5748598
    PICIA
    Help: 185
    Rate: 248
    it is also a raw material - steel
  • #7 5777073
    przemyslw
    Help: 6
    Rate: 86
    Separating the insulation where there is a thick copper wire with such a device will be successful, but how to remove the insulation from car lines, not to mention thin cables to electronics? And there's a big pile of it. Insert untangled cables one at a time? A little pointless.
  • #8 5777437
    ramhac
    Help: 7
    Rate: 119
    Put the ropes from the car into the acid.
  • #9 5777649
    przemyslw
    Help: 6
    Rate: 86
    Think before you start something.
  • #10 5779424
    lord_blaha
    Help: 177
    Rate: 112
    majster_15 wrote:
    Well, on a larger scale, it is probably only burned in a fire, but then they are only suitable for scrap metal or for hanging laundry ..
    And how to heat the cables in an old oven? The plastic will melt elegantly, and the copper will be fine, no soot ...
  • #11 5779623
    spidecki
    Rate: 9
    It's like this, we either burn or torture the cables and hands with sharp tools, or:
    http://www.hard.com.pl/zlom/
    there are no other methods.
  • #12 5780312
    Fyszo
    Level 37  
    Help: 223
    Rate: 115
    Are they cables as electric cables and not tension cables? So where does this steel come from?
    I am a little surprised - because you can get rid of insulation in industrial terms, you can use long wires - and these are then more valuable as a wire. On the other hand, clippings that are worth processing are not suitable for simple machines, and lines (braids) in particular.
The discussion revolves around alternative methods for removing insulation from copper cables without burning. While burning is a common method, it raises concerns regarding the legitimacy of the copper's source. Several alternatives are suggested, including using a mechanical stripping device that crushes the insulation, making it brittle for easy removal. There are also mentions of using acid for stripping insulation from car wiring, although this raises safety concerns. The challenges of stripping insulation from thin electronic cables are highlighted, with suggestions for industrial methods to improve efficiency. Overall, the conversation emphasizes the need for safer and more effective insulation removal techniques.
