SANYO Sanfax 200 - Printing Issue, Need Manual or Reprogramming to English
Jacck 1754 6
  • #1 417129
    Jacck
    Help: 83
    Rate: 105
    I have a problem with such an antique imported from Germany I think.
    Apparently it has stopped printing, it's a fax machine for thermal paper.
    If anyone has a diagram or manual I would be grateful. The only thing I could find on the web was a German installation manual, the menu on the display is unfortunately also German and I am a little weak in this language. Maybe it can be reprogrammed to speak our language, or at least English?
    There is a detachable flap underneath where EEPROM 27C256 is located, but I don't think it contains firmware (too small for my taste).
  • #2 418057
    infinity
    Phones specialist
    Help: 5
    Rate: 32
    I'm not very good at German either.
    But the messages are rather standard, so give on the forum, we will know where to start.
    About the Polish language you can forget about English, maybe, as it was intended for the German market it can be different.
    Look in Menu sprache - it is a German language:-) and try to switch to some human language such as English.
    Documentation - I have a lot of different but for sanyo fax machines I have never seen.
    Greetings.
  • #3 421590
    JARTECH
    Phones specialist
    Help: 26
    Rate: 32
    I will ask a trivial question. Is the thermal paper well inserted?
    I don't mean to make fun of you, it's just that sometimes routine eats away at us and we don't notice such simple things
    PPHU JARTECH
    Poziomkowa 14, krotoszyn, 63-700 | Company Website: www.jartech.pl
  • #5 21205222
    JARTECH
    Phones specialist
    Help: 26
    Rate: 32
    rjanetort wrote:
    Here are the instructions in English.
    https://www.manualslib.com/products/Sanyo-Sanfax-200-8748818.html
    change language settings
    language configuration
    https://www.manualslib.com/manual/148484/Sanyo-Scp200.html?page=8#manual
    After 21 years, I think the fax is rather gone....
    PPHU JARTECH
  • #6 21205519
    rjanetort
    Cześć,
    Mam taki, który nadal działa... szkoda, że ​​nikt już go nie używa.
  • #7 21205664
    JARTECH
    Phones specialist
    Help: 26
    Rate: 32
    rjanetort wrote:
    I have one that still works.... it's a pity that nobody uses it anymore.
    In the age of virtual fax numbers, emails and the whole internet, it is uneconomical to use a classic fax/telefax.
    PPHU JARTECH
The discussion revolves around a SANYO Sanfax 200 fax machine that has stopped printing. The user seeks assistance in finding a manual or reprogramming the device's language from German to English. Responses include suggestions to check the thermal paper insertion and a link to an English manual. Some participants express skepticism about the machine's longevity, given its age, while others note the decline in fax usage due to modern alternatives like email.
